Need help on E92 335xi front ball joints!
12-06-2019, 01:12 PM | #1 |
Rep 11
I am replacing my front thrust arms and control arms as well as the ball joint thats separate from the control arm. Got the control arm removed but the ball joint is not coming out. I hammered it, tried c clamp, and used a ball joint seperator and nothing worked. Any input or advice on a way to remove them.
Appreciate the help.
2009 335xi Coupe 6MT, VRSF dps, VRSF 7" FMIC, Chargepipe/ Tial BOV, UUC SSK, BC Racing Coilovers, JB4/BEF, Xdelete, ATM Speedshop 3.5in exhaust, Bucketless Stage 2 LPFP
12-06-2019, 06:24 PM | #2 |
611
Rep 1,272
Yeah, that one can be a real bitch. Took me like half a hour alternating between an air hammer and a 3-pound hammer with a big punch.
I think maybe what helped some was hitting the edge of the flange with a chisel to turn the joint. I think that went a long way toward breaking the rust. |
12-06-2019, 09:52 PM | #3 |
114
Rep 598
I just removed both. You need to hammer it while on a VICE. Otherwise the energy from hammer will be absorbed by all the other rubber bushings on the car.
Came out with a standard size ball-pean hammer. Nothing big. Going back in was easy after brushing off the rust and using brake hardware lube. |
12-09-2019, 09:25 AM | #7 |
1552
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
It's pressed into the upright on xi for the thrust arm.
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+ BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq. 2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast |
12-09-2019, 09:46 AM | #9 |
1552
Rep 3,475
12-09-2019, 10:00 AM | #10 |
114
Rep 598
Most of the weight on Xi comes from front axle shafts and the cast iron front uprights. The front drive shaft, and front diff doesn't weight much. Steel front sub frame instead of aluminum also adds weight along with transfer case. But not so much as axle and spindle / King pin / uprights
