Bimmerpost
4 Series
Technical Topics Cosmetic and Lighting Modifications (exterior & interior) M330i bumper for base model?
      12-05-2019, 07:05 PM   #1
haztronic
Drives: BMW 3301
Was wondering if anyone knows if the 330i M sport bumper could fit and replace the front bumper on the base 330i?
Haven't really found much info on this as it seems everyone has the 330i M sport package already lol (if only I had a bit more money ).
Cheers!
      12-05-2019, 10:18 PM   #2
VipinLJ
Petrolhead
VipinLJ's Avatar
1942
Drives: ‘20 330i,‘16 X3,‘18 SQ5,‘17 A7
Cheers!
It should. I don’t think BMW will redo the entire front end just to fit a different bumper.
      12-06-2019, 12:08 AM   #3
haztronic
Drives: BMW 3301
I guess one of the main reasons I ask is because on the m sport bumper, there are the extra lights which aren't on the base models.
      12-06-2019, 01:27 AM   #4
DomiGijzen
DomiGijzen's Avatar
Netherlands
70
Drives: BMW iX3 MSport High Exec (G08)
The bad has the fog lights as an option. Don't know if the cable is always prepared.
Grz D.!
      12-06-2019, 08:54 AM   #5
VipinLJ
Petrolhead
VipinLJ's Avatar
1942
Well yes. You’ll need the wiring, switch (on the headlight switch console) and coding (?) for the fog lamp to work. I was talking about the clips and stuff which should be the same, making it possible to install the M sport bumper in place of the ordinary bumper.
      12-07-2019, 12:44 AM   #6
juanmad
42
Drives: G20
Does anyone know where can I get a g20 M bumper? I would like to buy a front and rear one, however I don't seem to be finding anyone that sells them yet..
      12-10-2019, 12:30 AM   #7
stpddream
Drives: BMW 330i 2019
I was able to find this:
https://parts.bmwmonterey.com/a/BMW_...r/51_A302.html
but not sure that's everything you needed to replace a base model bumper though & how hard it is to replace it.
      07-13-2020, 11:12 PM   #8
jrs_nauman
Drives: 2020 330i sedan
Cheers!
OP, were you able to go through with this conversion? I'm asking because I am thinking of doing the same. Thanks!
      07-14-2020, 09:32 AM   #9
Lo2
Hong Kong
62
Drives: .
bumper mounts are different between the M and non-M
Other small components will need to be changed as well.
Including, but not limited to
lower re-bar
rebar shock absorber
all bumper trim pieces
      07-14-2020, 10:16 AM   #10
jrs_nauman
lower re-bar
Because the bumper mounts are different, would that mean that this conversion would not be possible to do?
      07-14-2020, 02:25 PM   #11
Lo2
Hong Kong
62
Drives: .
The conversion is possible.
It's just there are additional pieces that will need to be changed out besides the main bumper panel/trim pieces.
Some of the internal mounts and structure pieces are different between the M and non-M bumper.
g20
