BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > M3 Control Arm Kit for 335i ....worth it on a daily driver?
      12-03-2019, 08:06 PM   #1
iqraceworks
iqraceworks's Avatar
2001
Drives: 2007 335i
I need to go through the suspension components on my 07' 335i and replace them...the car has 100K miles on it, and the front end it sloppy.
I saw that ECT Tuning has this M3 upgrade kit for the 335i.....is there any real benefit from using this kit on a daily driver? And downside? Will it increase front tire wear? Any real downside? It's not much more than stock control arms.
Any info would be great. Thanks!
https://www.ecstuning.com/b-trw-part...102283577mkt1/
2007 335i, BMS DCI, BMS Chargepipe w/Tial BOV, ARM Catless Downpipes, silicone inlets, Bilstein B12 Prokit Suspension, Whiteline subframe bushings, Front/Rear M3 control arms, G-Plus FMIC, Stage 2 LPFP, Custom E40 tune by Justin (V8Bait), xHP stage 3 transmission flash, RB Two Turbos....10.90 @ 128mph
      12-03-2019, 10:05 PM   #2
200,000 club
28
Drives: BMW e90 328i 6MT
My uncle did a full M3 suspension conversion on his 335i, he says it's definitely worth it. I think doing just the control arms would not be worth, especially considering how much ecs charges for them. I would go with the full M3 suspension if I were you
      12-03-2019, 10:55 PM   #3
Soravia
114
Drives: 2011 E91 Silver xDrive 6MT
At that many miles you want to replace the ARMS and the bushings, FYI.
As for M3, the benefit is from the bushings. More solid bushings give better wheel control on the road. Something liquid filled bushings do not.
One set of M3 front lower control arm will give your more negative camber for front tires, automatically giving better control. You can also buy adjustable links off eBay for cheaper price. But they come with steel nuts that will corrode if you don't paint.
You can also fill OE hollow bushings will polyurethane and rock it like I'm doing. Some use other materials but I prefer more durable stuff like this.
      12-04-2019, 03:33 AM   #4
streetpro
streetpro's Avatar
Czech_Republic
87
Drives: e92 335iA
There is a huge benefit of having more camber - steering transforms from dull to eager...
Downside is a little bit of road noise transmitted into a cabin...
"If everything seems under control, you're not going fast enough.” Mario Andretti
      12-04-2019, 08:42 AM   #5
mweisdorfer
mweisdorfer's Avatar
1903
2007 BMW E90 335i  [0.00]
2008 bmw x5  [0.00]
I have the full M3 control arm kit from FCP with a lifetime warranty on it for both front & back. My 335i is my DD. It's definitely worth it, especially if you couple it with the Bilstein B12 Kit.
lab_rat394.50
      12-04-2019, 08:52 AM   #6
The Nightman
Cometh
The Nightman's Avatar
1090
Drives: Boy's Soul
I daily my E90. The M3 front tension struts yielded a significant improvement in handling and feel, but it came at the cost of increased NVH. I didn't use the M3 front wishbones and can still get -0.9° of negative camber with the strut mount pins removed. In hindsight, I should've went with the M3 wishbones as well since they also replace the inboard bushing with a bearing.
https://www.1addicts.com/forums/show....php?t=1094111
I'll be installing rear M3 guide rods soon, which replaces the inboard bushing with a bearing to better resist thrust and braking loads.
      12-04-2019, 09:14 AM   #7
iqraceworks
2001
Drives: 2007 335i
Does anyone sell a kit with all the arms, all the bushings, everything you need to go through the front end and freshen up everything?
      12-04-2019, 09:21 AM   #8
Soravia
114
I have xDrive so the front tension struts from M3 won't fit, not without some cutting.
I'm wondering if it will work to drain the liquid bushings and fill the cavity with polyurethane.
      12-04-2019, 09:21 AM   #9
iqraceworks
2001
Drives: 2007 335i
What about going with aftermarket performance bushings like Proform? Bad/Good idea?
      12-04-2019, 09:50 AM   #10
mweisdorfer
1903
2008 bmw x5  [0.00]
If you go with Poly bushings either A, the roads you drive on are pristine or B you track the car. Poly bushings really shouldn't be used is a DD.
When I redid all the bushings is the rear subframe, a had conversations with the folks at both ECS Tuning & FCP Euro. They both stated the above in the first paragraph. So, I did M3 control arms, M3 differential bushings & M3 subframe bushings. My car is a DD. Coupled with the Bilstein B12 Kit, the results were outstanding.
      12-07-2019, 11:26 PM   #11
Soravia
114
You can also drill the poly bushings to get a bit less vibrations.
      12-14-2019, 07:57 PM   #12
mweisdorfer
1903
2008 bmw x5  [0.00]
I don't think anyone does. They tend to group them though.
      12-16-2019, 01:16 PM   #13
Soravia
114
Replace whole arms. Bushing replacement on arms is PITA, even with press. Very hard to grab the arm while trying to press out Bushing unless you have adapters made exactly to fit. Not worth the money.
Control arms are designed to deform with curb and road impact. Just replace them. Cheap on eBay and aftermarket
      12-16-2019, 01:18 PM   #14
iqraceworks
2001
Drives: 2007 335i
The M3 control arm kit......comes with new M3 control arms.
      12-16-2019, 01:55 PM   #15
Soravia
114
Yes, I know. I have them. Talking about control arms in general.
      12-16-2019, 05:25 PM   #16
BM3Rrrr
Davy Jones, Giant Squid
BM3Rrrr's Avatar
No_Country
271
Drives: a Pirate Ship
FCP Euro sells the same kit for $297
I'm probably going to buy it along with the Sway Bar end links.
2010 e90 335i LCI - xHP - Mishimoto - BMS - CPe - Turbosmart - MHD - Eibach - Koni - VMR - LUX
      12-16-2019, 09:47 PM   #17
iqraceworks
2001
Drives: 2007 335i
Do you have a link to the FCP euro kit?
      12-16-2019, 10:50 PM   #18
feuer
feuer's Avatar
4276
Drives: wife crazy!
Depends where you drive like are the roads curvy or just straight city streets. Is the pavement smooth? How you drive, are you taking it easy or you are aggressive. How long long time you spend driving? The rest of the vehicle setup: tire profile, lowering springs....I think if this is mostly a city car, on streets with potholes and cracks one might find out that isn't worth it after experiencing the harsher ride....
      12-17-2019, 12:00 AM   #19
BM3Rrrr
BM3Rrrr's Avatar
No_Country
271
https://www.fcpeuro.com/products/bmw...rade-bmwmcakit
feuer4275.50
      12-17-2019, 05:35 AM   #20
mweisdorfer
1903
2008 bmw x5  [0.00]
This is the cheapest I've seen the front & rear in a long, long time.
https://www.fcpeuro.com/BMW-parts/33...8;d=788&v=
feuer4275.50
      12-17-2019, 08:42 PM   #21
Soravia
114
Cheaper if you get the parts from CarID ( one side for rear), RM European (the other side)
      12-18-2019, 11:39 AM   #22
mweisdorfer
1903
2008 bmw x5  [0.00]
Lifetime warranty? You want to pay for them again in another 75 to 100,000 miles? I wouldn't....
