n54 OEM motor mounts and 3M window weld
11-30-2019, 07:41 PM | #1 |
21
Rep 128
Any thoughts on adding window weld to a new set of motor mounts?
seems like an easy, cheap modification that would add some stiffness without much NVH (Noise, vibration, and harshness) but I wanted to know if anyone had any real thoughts on the idea? I know the IS mount is an upgrade but I wanted to explore this option. youtuber Vehicular DIY
CALIFORNIA SMOG LEGAL |
12-01-2019, 08:01 AM | #2 |
114
Rep 598
You can also use Polyurethane mixes. But here's the kicker, the bottom piece is still filled with liquid.
Good if you want less vibration, bad if you want performance of a solid rubber. Not sure how long that window weld will last next to engine heat. There's a ton of heat on turbo. |
12-04-2019, 07:06 PM | #3 | |
21
Rep 128
I just settled on just installing OEM motor mounts and will work on other parts of the suspension like the sway bars. thanks!
12-04-2019, 10:33 PM | #4 | |
114
Rep 598
About to put in poly on new cheap mounts I just bought. I will try to drill the OE mount BOTTOM and see if I want to replace the liquid that way in the new one as well. |
12-05-2019, 08:50 AM | #5 | |
1207
Rep 2,026
12-06-2019, 01:28 AM | #6 | |
114
Rep 598
Have to make sure the bottom holes are plugged though. Duct tape will work. The liquid is not thin. |
feuer4275.50 |
12-07-2019, 11:18 PM | #8 |
114
Rep 598
12-08-2019, 05:55 PM | #9 | |
21
Rep 128
12-09-2019, 08:48 AM | #10 |
87
Rep 236
Drives: e92 335iA
window bond/weld won't do anything, it stays in place, filling the gap... the same with epoxy, I doubt it cracks and slips away...
"If everything seems under control, you're not going fast enough.” Mario Andretti
12-09-2019, 09:06 AM | #11 |
1207
Rep 2,026
Get back to me in a year and say the same. Two different durometers, molded at separate times, will inevitably separate from one another. Especially "window weld" since it's not actually poly. It will harden and crack away. Quick google search shows just about anyone who as ever done it say the same.
12-10-2019, 04:46 AM | #12 |
87
Rep 236
Drives: e92 335iA
I agree... it does harden and crack away but as long as has no chance to fall anywhere, it just stays and prevent excessive movements...
