11-28-2019, 10:10 AM | #1 |
95
Rep 572
Changing the gear knob
Anyone try doing this crazy mod? upgrading teh standard gear knob for the m5 one?
Daily: Porsche Panamera 971 | BMW 520xD G31
Sh!tbox: BMW Z4 M E86 | BMW 1M E82 | BMW M3 E90 Insta: bmw.shitbox |
12-27-2019, 10:25 PM | #3 |
472
Rep 888
Drives: 2019 M550i
If it doesn't included programming I don't know why you'd bother, just get an M5.
clee1982797.50 Mosaud19983940.50 |
12-28-2019, 06:33 PM | #4 |
1708
Rep 2,539
Agreed. Never been a fan of transplant or frankencars. If you really crave the M5 shifter, just get the real thing.
2017 BMW 530i, Sport Line,Alpine White, Canberra Beige Sensatec, 19 inch V-Spoke wheels, basic plain Jane build with no options whatsoever..... "Less is more".
Before: 2011 BMW 328i E90 sedan, Platinum Bronze Metallic, Dakota Brown leather, 17 inch wheels, 6-speed auto, N52 6 Cyl inline N/A goodness.... |
clee1982797.50 |
12-28-2020, 04:50 PM | #5 |
23
Rep 47
12-30-2020, 10:10 AM | #7 |
1708
Rep 2,539
Cheesy option in my opinion
01-23-2021, 03:18 AM | #9 |
Rep 7
Not installed it but contemplating with the idea of going ahead with the crystal Knob. Few on these knocking around on ebay including the Crystal start stop button.
02-06-2021, 07:53 AM | #10 |
31
Rep 77
Must admit the crystal shifter looks cheesy in images, but in real life it looks alright.
Passable as long as there's only 1 fake crystal piece in the car. Looks chavvy when its plastered to half the interior dials. It aint cheap either. Just had a search; £400 is the lowest I could find on AliExpress (china). Last edited by mittu; 02-06-2021 at 08:02 AM.. |
03-04-2021, 03:00 AM | #11 | |
45
Rep 135
01-03-2022, 10:00 AM | #12 | |
78
Rep 449
'17 F80 (RET)
'14 F22 M235i (RET) '11 E90 335i (RET) '07 E92 335i (RET) '89 E30 M3 (RET) |
01-05-2022, 03:59 PM | #13 |
78
Rep 449
I noticed in some pics the shifter sits about 1" taller than the fitment on a G20. Was going to pull the trigger on this but will wait to see how it works out for you!
'17 F80 (RET)
02-01-2022, 07:49 AM | #14 | |
1164
Rep 2,180
This is the G20 shift knob fitment: |
02-09-2022, 08:34 PM | #15 |
31
Rep 77
Crystal gear and dials arrived a couple weeks ago.
Not had time to fully instal. Got caught up sweating my socks off with covid. Ive done the buttons/dials across the dash. Using the included sticky silicone putty, the Start and Auto climate buttons were easy enough to swap out... and then there's the volume dial. The face of the Start and Auto climate buttons are direct replacements, but for the Volume button its a cover that sits over the original, resulting in very little to no light passing through. It sounds petty, but its annoying as hell and stands out like a sore thumb. Turns out the volume button isn't so easy to remove. The face of it is one piece which is part of the dial structure attached to the mechanism on the inside of the panel. It annoyed me enough to have a brilliantly stupid idea... drill the top of the button! Gotta risk it for a biscuit. Last edited by mittu; 02-16-2022 at 08:36 AM.. |
540iSUP704.00 Bayarea 530i g309.00 |
02-15-2022, 04:54 PM | #16 |
31
Rep 77
Crystal gear knob and iDrive wheel instal
Please note this is only for the G30/G31, G11, G01, G02... and the G38
We’ll start with the star of the show, the crystal knob. There are 2 types: gear knobs without drive letters, and those with. WITHOUT drive letters When searching, this type is the most common. Has a static light-up character in the glass (5, 7, X3, M, etc.) Although cheaper and easier to find, the installation requires more work. Complete gear shifter unit must be taken out of the centre console and partially disassembled. This is required to swap out the ribbon connector. Removing the centre console top trim isn’t difficult. A few clip and screws, nothing technical. Centre console trim removal video: https://www.youtube.com/watch?v=QNlanprZaIA The replacement ribbon connector contains a bit of circuitry to program out the drive letter lights. They should’ve integrated this into the gear knob PCB, but this is actually a cost saving measure so they can use the same PCB found in their crystal MGU gear knob; their hot seller. Once the ribbon connector is swapped out, the new gear knob can be fitted as normal and the shifter unit reinstalled back into the centre console. Ribbon swap and gear knob fitment video: https://www.youtube.com/watch?v=Eq22_ARsfjU As well as the videos above, a step-by-step PDF is attached. WITH drive letters Costs more, offering integrated light-up drive letters like OEM gear knob. Depending on the brand it may not require a ribbon connector change. MankaleiLab (MKL) brand: Ribbon change necessary similar to above, requiring trim and shifter unit removal. Vstar brand: A much easier instal. Just swap out the gear knob. No centre console trim removal needed. All necessary circuitry is built into gear knob PCB. Does not require ribbon connector change. No need to remove shifter unit or centre console trim. iDrive wheel Most gear knob sets include the circular crystal touchpad glass, and some also include the bezel ring for the wheel and other buttons for the dash. Touchpad replacement Touchpad can be swapped out easily. No centre console trim removal needed. Simply unclip the top of the wheel, disconnect ribbon cable, warm up and remove top surface layer & adhesive residue. Stick on new crystal piece and clip it back in. Job done. Wheel ring bezel Requires the centre console trim to be removed. iDrive wheel/ switch unit will need taking out and partially disassembling. If you aren't fitting any other dials with the same matching bezel, then its not worth swapping out just the iDrive wheel ring bezel; too much effort and wont match OEM dial bezels. The bezel ring is clipped in from the inside of the wheel, which is screwed down to the switch unit from the underside. Replacing it involves several steps, but nothing complicated. Step-by-step PDF attached. Video of complete bezel ring replacement and crystal touchpad: https://www.youtube.com/watch?v=tXmiZObpbSU Summary Its fairly easy for anyone with no car knowledge to swap out the gear knob and touchpad without the need to remove any car trim (Vstar brand) Sometimes the brand name is stated in the product description, and if not, double check with seller before buying. Do not rely on product photos as most listings use a mixture of stock images. Sellers intentionally don't mentioning trim removal and ribbon connector change. Some avoid showing you the included replacement ribbon. The Vstar model is a hassle-free straight swap with the OEM gear knob. They’ve best sussed out the circuitry, so given enough time, the other makers will do the same. If you prefer the look of the cheaper ones or the MKL brand, or fitting the wheel ring bezel, then be prepared to remove a few pieces of car trim. RIGHT HAND DRIVE cars If the product page doesn’t specify LHD or RHD, assume its for LHD cars. Only difference is which side the ‘unlock’ button is on. Fitment is the same. Finding a RHD version with light up drive letters at a reasonable price is a little tricky. I’ve asked a couple of sellers, who’ve said the LHD version can also be fitted to RHD cars. Shifter movement pattern is exactly the same for both LHD & RHD, and the placement of the ‘unlock’ button doesn’t make a difference in the real world. Hopefully this info helps. I’ll revise and update it if needed. Last edited by mittu; 02-16-2022 at 04:18 PM.. |
540iSUP704.00 |
02-16-2022, 09:15 AM | #18 | |
31
Rep 77
https://www.aliexpress.com/item/1005...rch-mainSearch Last edited by mittu; 02-16-2022 at 10:03 AM.. |
02-22-2022, 08:44 AM | #19 | |
31
Rep 77
The spacer fills the extra height of the metal shifter pole which the gear knob mounts on. If you really wanted you could trim down the pole with an angle grinder. An inch should do the job. Or do what I've done... Spray it sliver. Had a random can knocking about in shed. I think it's come out ok. |
07-23-2022, 08:09 AM | #20 |
31
Rep 77
Ive now installed and sold 30 of these gearknob. The brand to buy is Vstar. Far superior construction and build quality compared to MankaleiLab (MKL).
08-17-2022, 01:47 AM | #21 |
73
Rep 198
08-19-2022, 12:29 AM | #22 |
73
Rep 198
