11-27-2019, 10:51 PM | #1 |
217
Rep 210
I replied with this info in another post but figured I would start a new thread since I've seen the topic arise a few times.
To keep the valves open: - Start and put in Sport + - Blip throttle to open - Crawl under and unplug both actuators They will remain in their last position until hooked back up. You can buy a connector plug (or just seal the end up with tape) to keep dirt from getting it it, then just zip tie harness out of the way. https://www.ecstuning.com/b-genuine-...r/18302411427/ UPDATED: Found plug blanks for the actuators https://www.wildwext.com/search?cont...8;s=7549032-02 I've done this on my M2 and X3M
2020 X3MC, 2019 M2C
'14 F-150 Tremor, '99 Mustang Turbo |
11-27-2019, 11:47 PM | #2 | |
47
Rep 154
12-04-2019, 12:49 AM | #6 |
Craig
233
Rep 389
does the connector plug protect harness and exhaust connectors ?
f97 x3m competition Donnington/Adelaide.
f80 m3 competition pack white/black gone f15 40d space grey/ ivory/black gone f31 335i mineral grey/coral gone but will be missed. gone 2014 range rover sport dynamic. |
12-04-2019, 04:58 AM | #7 |
217
Rep 210
No. You'll have to put some electrical tape over the actuator plug to protect it from the elements.
2020 X3MC, 2019 M2C
Craig 1527232.50 |
12-04-2019, 11:44 AM | #8 |
5004
Rep 6,865
What does the exhaust button in the x3/4m control if not the valves? In my M3, the valves are controlled automatically based on the engine setting (efficient/sport/sport+) and throttle input. But the x3m has an actual exhaust button...what does it do?
12-06-2019, 10:36 PM | #9 |
217
Rep 210
Updated with plug blanks for the actuators.
2020 X3MC, 2019 M2C
Craig 1527232.50 j080808129.00 |
12-07-2019, 02:14 PM | #10 |
USA
129
Rep 217
Found these (male and female sides) on AliExpress
https://www.aliexpress.com/item/3284...5dbb4c4dZZjJRw 2 sets for 16.11 shipped. Ill advise once they are installed. |
AJCC22.50 Craig 1527232.50 |
12-07-2019, 05:09 PM | #11 | |
2810
Rep 5,316
Drives: G80 M3 6MT
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
01-01-2020, 05:17 AM | #12 | |
207
Rep 668
Can you access the actuators without a ramp? Last edited by Zero71; 01-01-2020 at 05:23 AM.. |
01-01-2020, 05:52 AM | #13 | ||
47
Rep 154
I didn't have the connectors so electrical tape and small plastic bag did the job with zip tie.
2020 X3MC BSM/2017 S5 B9 St 2 - Current
2014 M6 F13 Coupe SO 2012 RS3 St 2 |
01-01-2020, 06:23 PM | #14 |
207
Rep 668
I read on the G01 forum that fuse 203 disables the actuator too - anyone try that on the he X3MC?
Regarding the actuators - is there one connector on each side, anyone have a photo of what needs unplugging? Last edited by Zero71; 01-01-2020 at 06:30 PM.. |
sd306380.50 |
01-01-2020, 08:55 PM | #15 |
Rep 8
Maybe I’ll try this tomorrow unless someone advises against it
01-01-2020, 09:32 PM | #16 |
2810
Rep 5,316
Drives: G80 M3 6MT
Can't hurt really, pop the car into sport plus, pull the fuse, put it back into efficient and see what happens. If no other adverse effects are noted and the desired change happens, then I'll prob also go with this method.
Scott, Partner
01-02-2020, 02:47 AM | #17 |
207
Rep 668
Can I check a couple of things...
How many actuators do we have? I gather from the G01 forum that the M40i only had one and it impacts the left exhaust only. I'm assuming we have two, one each side? The G01 appears to close the left exhaust on start up for faster warm up, then opens after 30 secs, so they get a louder start up, even in Sport+. I think the X3MC is open both sides on start up and closes at least partially as you move off as it gets quieter after startup? Process on G01 seems to be to drive for 5 or 10 mins to open valves, yet our car it seems to be just cold start it. So the exhaust is operating quite differently? One guy on G01 forum suggested his valve vibrated closed over a number of weeks after deactivating valve. Is this possible? I thought they were motorized and would be locked in place by the powered off motor. |
01-05-2020, 01:10 AM | #19 | |
Craig
233
Rep 389
did anyone try the fuse method yet ?
01-06-2020, 09:40 PM | #20 | |
USA
129
Rep 217
There are two valves, one on each side, and yes, they are accessible while the car is on the ground. |
01-07-2020, 04:53 AM | #21 | |
1364
Rep 2,495
Arrived! 2022 X4M Competition, SPY + Black Merino
Gone: 2019 X3M Competition, Toronto Red, Adelaide Grey. |
01-07-2020, 05:37 AM | #22 |
Craig
233
Rep 389
Moff you can order them from AliExpress just copy link above I ordered two sets cost was just over £16 delivered had email to say there posted so hope they should be here soon wont fit them till get the RIS done
