11-26-2019, 07:07 PM | #1 |
Rep 21
2014 F30 N26 V band clamp help!!!
Doing a VRSF catless downpipe install on my 2014 F30 328i xDrive (N26). i was told I needed a 4inch v band clamp because more than likely my stock one will break. Any links or product numbers would be greatly appreciated!! I have been trying to look for some , but only find ones for the N20 :
11-26-2019, 09:01 PM | #2 |
1599
Rep 3,748
#6
https://www.realoem.com/bmw/enUS/sho...diagId=18_0987 Seriously use this website in the future... put it on your bookmark Mine F36 but still have n26...so the same cat. |
11-26-2019, 09:19 PM | #3 | |
Rep 21
Mine F36 but still have n26...so the same cat.[/QUOTE]
That one is 2 1/2 inches, I need 4 inches :/ |
11-26-2019, 09:36 PM | #4 |
153
Rep 414
The site above is correct. There are 2 clamps you may need to replace. Several threads on this but you’ll want to have these 3 parts on hand.
18307581970 gasket 18307606136 screw clamp 18307628660 muffler clamp |
11-27-2019, 01:53 PM | #6 |
480
Rep 681
Number 3 is the 4" clamp from RealOEM. Its the turboside clamp that can break as well. The midpipe side one was tacked onto my midpipe but it was fine to reuse.
2016 328ix F31 - SOLD!
2006 997.1 C4S |
12-05-2019, 08:50 AM | #7 | |
20
Rep 109
What I ended up doing was having my friend position the v band clamp and then at the connection point to where the bolt goes into he used a plier to fully clamp it down to where it locked the downpipe to the turbo in place at that point you shouldn't need to have to hold the downpipe up anymore as that clamp will do it for you, that is when you know it is locked down, then you just put the bolt in ofc I changed the inside gasket but reused the original v band clamp, ended up destroying the mid pipe clamp tho |
12-05-2019, 08:53 AM | #8 | ||
20
Rep 109
12-05-2019, 10:43 AM | #9 | |
1599
Rep 3,748
Anyway back to your post.... you don't install from the exhaust back to the dp... that is backward.. You need to loosen up the catback exhaust (if you have one) if it is stock loosen the hangers. Install the dp first then aligned the exhaust and tighten up |
12-05-2019, 10:51 AM | #10 | ||
20
Rep 109
