11-26-2019, 01:54 PM | #1 |
76
Rep 233
Automatic Headlight on/off sensitivity
My headlights are often on (automatic setting on headlight switch) when it is quite bright out with sunlight all over the top of dashboard. Seems more likely when weather is cold. They will eventually switch off, but cars I've had before would go on when entering a tunnel and off within 5-10 seconds after leaving it. Anyone know a way to adjust it? Nothing in the owner's manual.
2015 Mineral White 335xi Sport trim
11-26-2019, 02:28 PM | #2 |
E36fiend
285
Rep 637
Drives: 2014 435i xDrive
Not adjustable from the car, if it's possible it'll be in the coding parameters.
11-26-2019, 02:30 PM | #3 |
8245
Rep 16,089
It can be coded with Bimmercode, E-sys etc. It's more of an issue when the weather is cold because that's also when the sun is low in the sky.
11-26-2019, 03:31 PM | #4 | |
806
Rep 1,906
Thanks/Bill |
11-26-2019, 03:44 PM | #6 |
238
Rep 878
I’ve not coded anything and mine seem to do their stuff when I would normally have switched the lights on. Pity the wipers aren’t as well thought out.
11-28-2019, 05:09 PM | #7 |
2025
Rep 2,806
Drives: F33 430 and F39 M35i
Try changing FEM Rain-Light-Sensor Sensitivity.
12-19-2019, 06:48 AM | #10 |
76
Rep 233
???????? Where is that at??
12-19-2019, 09:06 AM | #11 |
175
Rep 614
Drives: 2016 F36 M Sport
In BimmerCode:
Front Electronic Module > Lighting > Rain-light-sensor sensitivity Options are: Insensitive Normal Sensitive Very sensitive
2016 BMW 428i Gran Coupe, M Sport, Glacier Silver Metallic
