11-25-2019, 01:58 PM | #1 |
Rep 45
What to look for on a used 2013 328I xdrive
I'm looking into buying a 2013 328I X drive. I've owned an E90 before, not familiar with the F30s. What should I be looking for before buying a used one?
Thanks for the help |
11-25-2019, 08:05 PM | #2 |
17
Rep 72
By no means an expert here. I think it would be valuable to find out if the maintenance has been done regularly, either with reciepts or though dealer if owner took it to one. Gaskets, like valve cover may be possible to observe for leaks.
11-26-2019, 09:05 AM | #3 |
108
Rep 276
Wouldn't consider an n20/26 prior to 2015 as it could have the dreaded timing belt. Shouldn't be too much of a price difference to have some peace of mind. 2016 or late 2015 is LCI and I'd recommend looking at this as well. I have pre lci and I get upset looking at my ugly headlights every day
11-26-2019, 10:04 AM | #4 |
I can haz cheezburger?
6799
Rep 3,677
Drives: 14 Sahara/08 335xi/22 Maverick
What is your budget? As mentioned above, I would try and go for a post 03/15 built N20/N26 if you are set on the 4 banger regarding the TC issues. Or you can look for a 2012 and on 335i and not worry about any TC crap.
11-26-2019, 10:36 AM | #5 |
168
Rep 268
Features. get one with all the features you want. Navigation, PDC, Parking Assist, 8in screen, m-sport, sport, wheels etc. I would aim for one with everything you want already installed. Not to say you couldn't add things, but it's a way easier if everything is already in the car that you want.....some things can't just be coded in.
11-26-2019, 10:48 AM | #6 |
806
Rep 1,906
a reputable independent BMW/Euro shop to do a pre-purchase inspection once you locate a car you feel is the one that fits your needs.
11-26-2019, 11:41 AM | #7 | |
poopycat
266
Rep 791
F30lolz6798.50 |
11-27-2019, 01:16 PM | #9 |
E36fiend
285
Rep 637
Drives: 2014 435i xDrive
More than anything, get an inspection done once you get serious about buying, can't emphasize this enough.
Prior to that, make sure you're solid in the features you want so you don't end up with buyers remorse because you didn't get m-sport, nav, PDC, HK speakers or whatever. Retrofits will always cost more than buying the car with the features you want already installed. |
Wgosma806.00 |
11-27-2019, 01:28 PM | #10 | |
157
Rep 425
From what I've seen/read, this is the one option where even the expensive retrofit comes up way short. Most everything else, such as audio, can be relatively straightforward to add later. |
