11-22-2019, 01:56 PM | #2 | |
160
Rep 741
mine is off when i start the car unless i shut the car off while it being on it will turn on automatically when i turn on the car. |
11-22-2019, 02:45 PM | #3 | |
1599
Rep 3,748
All car I drove does this... You leave it on .... its stays on You leave it off.... its stay off So far I haven't drove one yet that's different |
11-22-2019, 03:16 PM | #5 |
160
Rep 741
my friend with an x5 had what the OP is describing, everytime i got in his car even in the winter the damn ac would always come on. now i was never able to confirm if he turned off the ac before he shut off the car, i thought it was bmw thing, until i got my own and discovered it wasnt... lol
11-22-2019, 03:16 PM | #6 |
160
Rep 741
doesnt it stress the motor/engine if you turn it on as soon as you start your car? i usually wait a few mins before i turn it on manually.
11-22-2019, 04:56 PM | #7 |
8245
Rep 16,089
The only things that come on as soon as you start the car are the indicator light and fan. After the car determines the temperature inside the cabin it then engages the compressor if it requires cooling, or it goes into heating mode if it requires heating. Of course the heating doesn't happen until the coolant temperature comes up.
11-22-2019, 05:11 PM | #8 | |
160
Rep 741
11-23-2019, 03:23 AM | #10 |
238
Rep 878
When he says fan he’s talking about the little piddly blower fan for the ventilation, with the engine already running this won’t stress anything. I always leave mine set to Auto all year round and just let it do it’s thing.
11-23-2019, 07:56 AM | #11 |
8245
Rep 16,089
Even without the engine running it won't stress anything. That's why you can set the fan to come on at a given time to ventilate the cabin per the Parked Car Ventilation section in the Owner's Manual. It's that big book that the dealer gave you when you bought the car that you still haven't gotten around to looking at.
Kingpin4386.50 veloella2210.50 |
11-23-2019, 08:32 AM | #12 |
25
Rep 110
Typically set mine to auto when its warmer out. In winter I manually set the fan speed and temps, If it's humid (rare when its cold) then ill change back to auto, but Ive noticed the car will turn on the AC even if set to manual if the cabin humidity gets too high.
11-23-2019, 09:19 AM | #13 | |
806
Rep 1,906
My X3 has this type of compressor, I can't sense it engage/disengage when pressing a/c button on dash controls as it is always engaged. Maybe F30 uses similar compressor? |
11-23-2019, 09:27 AM | #14 | |
160
Rep 741
..... no comment can i interest you in a beer? |
11-23-2019, 09:28 AM | #15 |
160
Rep 741
11-23-2019, 04:03 PM | #18 |
1646
Rep 4,877
If the compressor does run, the seals can dry out, and then it will leak refrigerant.
For the record, the AC compressor cannot run at temperatures less than freezing, or the condenser freezes. There is no point in turning it on/off, just set it to auto and forget about it. |
11-24-2019, 03:43 PM | #20 |
171
Rep 468
Humidity sensor
the reason your AC comes on because your car is obviously fitted with humidity sensor. As soonest there is any bit of humidity, the AC runs regardless of your panel settings.
A one of those stupid BMW features |
11-25-2019, 07:37 AM | #21 |
21
Rep 49
I've also noticed that the car will run the AC compressor, even with the compressor switched off), when in auto and the humidity is high or there is the slightest amount of window fogging. It switches itself back to a compressor off condition after a few minutes.
11-25-2019, 08:11 AM | #22 | |
391
Rep 849
Drives: BMW 435i
I've previously owned cars without climate control and always had to turn the A/C on in the winter to keep the windows from fogging up when carrying passengers when the weather was rainy or really cold. |
