E93 328i alignment question: Can't align unless loaded?
11-22-2019, 11:00 AM | #1 |
![]() 43
Rep 187
First, I am fairly new to newer BMWs. Second, this is second hand, as the E93 is my father's new car.
The car was taken to a shop to get a 4 wheel alignment. He's having it aligned because the rear wheels had wear on the inside edges. It's a 2010 328i with sport package and optional 18" wheels. The shop told them they could not align the car because it needed to be pre-loaded, or represent 4 adults in the car. This did not sound right to me, so I figured I would ask here.
2016 F31 M-Sport THP | 1998 Z3 1.9L Dinan Stage 3
11-22-2019, 11:16 AM | #2 |
Grandmaster
768
Rep 798
I think that the by-the-book BMW official alignment procedure does describe putting weights in the car to represent driver, passengers, and loads in the trunk or whatever... so in a way, the shop is technically correct.
I don't know this for sure, but I think most shops just align with no weights and 95% of the time everything works out fine. Maybe you could find a different shop that specializes in BMWs or European cars to do the alignment for you?
Daily - 2018 Alpinweiß ///M2 6MT Exec Rain/Snow/Winter - 2011 328i 6MT Sedan - Black on Black, Sport Package Sold, But Not Forgotten - 2009 135i 6MT - Black on Black, M-sport, JB4 |
11-22-2019, 11:22 AM | #3 |
![]() 1209
Rep 2,476
It does, the dealership will place weights in the car. Race car teams often do alignments with the driver/gear in the car. With that said, an alignment without those weights is still much, much better than no alignment, and most shops will do it.
The next issue you'll likely encounter, unless they've been replaced recently, is the outer tie rod ends seazeing to the inners. |
11-22-2019, 11:25 AM | #4 |
![]() 107
Rep 202
A non-specialist garage with somewhat older equipment is likely being straight with you about the prescribed method given in their reference materials. A lot of older Bentley manuals and even BMW technical service information for older models prescribe loading the car with weights to simulate typical loaded driving conditions.
BRR Tuned
11-22-2019, 08:25 PM | #5 |
![]() ![]() ![]() ![]() ![]() 114
Rep 598
TYPICAL driving conditions.
What do you drive with? Mostly half tank of gas and ONE driver, right? That's how you do alignment. I ask the shop to load up one of their employees in the car. Obviously they won't let me in the bay for insurance |
Wolf 3352340.50 |
12-01-2019, 04:58 PM | #6 |
![]() 43
Rep 187
thanks for the information. Based on that, it has an appointment at the BMW dealer to get it done. Figured that would be best.
12-01-2019, 05:20 PM | #7 |
![]() 2001
Rep 3,731
I would think that you want the car set-up how it's going to be normally driven. If you don't drive around with 4 adults and a trunk full of crap....why would you get it aligned with all that weight in the car?
12-10-2019, 11:53 PM | #8 |
Cometh
1090
Rep 1,305
Drives: Boy's Soul
BMW specifies to load the car down to "normal position" as follows:
Vehicle with complete equipment for normal operation with: 2 x 68 kg on front seats (seats in central position); 1 x 68 kg on rear seat (centre); 1 x 21 kg in luggage compartment (centre) and full fuel tank. https://www.newtis.info/tisv2/a/en/e...rement/6KsEXqW |
12-11-2019, 07:05 AM | #9 | |
![]() 2001
Rep 3,731
All that being said.....I've NEVER seen an alignment shop ever put weight in a car before they align in......not that it's a bad idea...
2007 335i, BMS DCI, BMS Chargepipe w/Tial BOV, ARM Catless Downpipes, silicone inlets, Bilstein B12 Prokit Suspension, Whiteline subframe bushings, Front/Rear M3 control arms, G-Plus FMIC, Stage 2 LPFP, Custom E40 tune by Justin (V8Bait), xHP stage 3 transmission flash, RB Two Turbos....10.90 @ 128mph
12-11-2019, 07:13 AM | #10 | |
![]() ![]() 4338
Rep 6,196
