Additional parts needed for ST Coilover install?
11-22-2019, 10:37 AM | #1 |
6MT FTMFW
61
Rep 229
Drives: 11 E90 335xi E91 6MT 12 X5 35i
Garage List 2005 330ci Vert ZHP [0.00]
2011 335xi Sedan M- ... [0.00] 2011 328xi Wagon M- ... [0.00] 2012 X5 35i M-Sport [0.00] |
I just bought ST Coilovers for my '11 335i xDrive, and I'm trying to figure out what else I should replace during the install. I've already got Monroe rear upper mounts, and plan to get the rear lower mounts and front upper mounts.
Is all of the other hardware really necessary? For example, all these parts in the ECS kit: https://www.ecstuning.com/b-assemble...1306775098kt1/ Thanks edit: will also use Prep-All and clear engine enamel on bodies, and anti-seize on the threads
2011 LMB E90 335xi 6MT: Wagner EvoII FMIC, Catless DP, PE Mod, Cobb CP, BMC Filter, ST Coilovers, Strongflex TSB's, Whiteline RSFB Inserts, CDV Delete, Hawk Talon Rotors & PC Pads
2011 SGM E91 328xi 6MT: 3-Stage Intake Manifold, ST coilovers, 335i brake kit, drilled/slotted rotors, CDV Delete, Charcoal Filter Delete Last edited by drummr8; 11-22-2019 at 11:49 AM.. |
