2011 BMW 335i e90 tires
11-20-2019, 09:52 PM | #2 |
611
Rep 1,272
11-25-2019, 04:12 PM | #3 | |
Rep 22
11-25-2019, 05:42 PM | #5 |
1903
Rep 6,968
11-25-2019, 06:07 PM | #6 |
Rep 22
11-25-2019, 06:14 PM | #7 |
3540
Rep 3,052
No one can tell you unless you tell us what wheel you have, picture or style number will help. Also, original or aftermarket suspension?
Twnturbo335i9.00 |
11-25-2019, 07:01 PM | #8 | |
Rep 22
And yes suspensions and rims are OEM |
11-25-2019, 07:50 PM | #9 |
3540
Rep 3,052
I also have Style 189’s and run Michelin 235/40/18 and 265/35/18 and wouldn’t go any larger.
Twnturbo335i9.00 |
11-25-2019, 07:55 PM | #10 |
Rep 22
Are your OEM tires for your rear wheels 255/35/18 right ? Are you having any issue with 265 ? I'm just trying to order tires online and want to make sure 265 fits on 8.5 inches
11-25-2019, 10:49 PM | #11 |
1161
Rep 3,189
They will fit but aren't recommended. 255 is really as wide as you would want to go. You can go up to a 255/40/18 and 225/45/18 in the front. Are you trying to increase traction or just for looks?
Twnturbo335i9.00 |
11-25-2019, 10:55 PM | #12 | |
Rep 22
11-25-2019, 11:05 PM | #13 |
392
Rep 2,367
Drives: 2011 335i
I run a size wider than stock
11-25-2019, 11:40 PM | #14 |
I can haz cheezburger?
6803
Rep 3,677
Drives: 14 Sahara/08 335xi/22 Maverick
I’m lowered sitting on 19’ style 313’s and fronts are 235/35/19 and rears are 275/35/19’s. Had a rear flat up in Orlando back in April on a Sunday morning and I had 265/30/19’s on the rear and nobody had that specific tire size new/used but found someone who had the 275’s so I took the plunge. Only rubs when two ppl sit in the back.
11-26-2019, 09:48 AM | #15 |
1903
Rep 6,968
Probably 265/35/18 is the widest you can go without rolling the fenders. That would be my guess. I know guys with M-sport suspensions can run 265/35/19 in rear but that's the limit without rubbing.
Twnturbo335i9.00 |
11-26-2019, 09:59 AM | #16 | |
Rep 22
11-26-2019, 12:57 PM | #17 | ||
1903
Rep 6,968
235/40/18 - front 265/35/18 - rear That would be a sweet set up for tires. You'll definitely notice the difference in the corners of a curvy road. |
Twnturbo335i9.00 |
11-26-2019, 01:06 PM | #18 | |||
Rep 22
11-26-2019, 03:08 PM | #19 | ||||
1903
Rep 6,968
I'd check with the tire shop to see if they will install a 265 on your 8.5" rim. Most likely you are ok. I have 255 on my 8" wide rims. FYI... If not, take advantage of a Black Friday deal on some rims. ECS Tuning has a nice stock of them to choose from. |
11-26-2019, 09:20 PM | #20 |
3540
Rep 3,052
I’ve been running 235/40/18 and 265/35/18 for just over a year without an issue. I haven’t had two people in the back but have had about 250 lbs in photo gear between the back seat and trunk.
11-26-2019, 10:55 PM | #21 |
1161
Rep 3,189
The issue of running a 265 on a 8.5" rim is not that you will rub, it's that it will handle turns worse.
Twnturbo335i9.00 |
11-26-2019, 11:08 PM | #22 |
Rep 22
