11-20-2019, 11:39 AM | #1 |
24
Rep 199
Question about 340i exhaust on 328i
I researched that a lot of people buy the 335i/340i back box and fit to a 328i.
I purchased a 340i exhaust system and cut the rear box off it. However, my local bmw specialist garage said they can't do it as the pipe is too flat? They apparently have fitted plenty to the diesels as they are more rounded. Apparently there is sleeve they used and it won't fit this shape of pipe. Pics show the pipe shape and where I cut it from the full exhaust. am confused. Can this be fitted or have I wasted my money on this exhaust? |
11-20-2019, 11:51 AM | #2 | |
1599
Rep 3,748
According to the picture you posted, the exhaust was cut on the wrong area.... look closely you should see a dimple 3" to 4" from where its cut. That were should be cut Then look at your 328i exhaust should have the same dipple... I just hope you haven't cut it yet on the wrong spot or else you need some exhaust shop to install this by welding. Good luck |
11-20-2019, 12:33 PM | #3 | ||
24
Rep 199
11-20-2019, 12:42 PM | #4 | |
1599
Rep 3,748
How far from the box muffler. |
11-20-2019, 12:46 PM | #5 | ||
24
Rep 199
11-20-2019, 04:01 PM | #6 | |||
1599
Rep 3,748
and I circle on your image where the cut should have been... 2nd image also..the 340i exhaust pipe diameter is bigger than the 328i.
JUST an F36....extra door, slower than you
AWE Quad Exhaust, Bootmod3 VMR v804 GM 19" Staggered |
11-21-2019, 03:23 AM | #7 | ||||
24
Rep 199
11-21-2019, 08:56 PM | #8 |
1599
Rep 3,748
02-07-2021, 07:10 PM | #10 |
Rep 29
I put a 335 muffler on my 328 and it wasn't a direct bolt on. My shop had to weld it together as the diameter is different on the mid pipe. The 328 was 3"OD and the 335 was 3.125" OD. Also be careful at which angle you cut the mid pipe, that could also mean you have to weld it.
