F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Possible to have cold starts with closed wastegate instead of open?
proTUNING Freaks
      11-16-2019, 04:39 PM   #1
Zabiz
Zabiz's Avatar
20
Drives: 2014 BMW 328i
My mom has a 2014 gl550 with the 4.7 L twin turbo v-8 and when it goes through its cold start you can hear the turbos spool which I am assuming means that the wastegates are closed (pneumatic)
now is that possible to get a turbo spool when we start up our cars (close EWG)
I have catless downpipes and a custom axleback so I can hear it when in sport + but cold start turbo spool would be nice
(if you listen closely you can hear the distinct turbo spool)
      11-19-2019, 01:12 PM   #2
CandyRedRC46
CandyRedRC46's Avatar
242
Drives: 2013 328i
I dont think that has anything to do with the wastegate. I don't see why the waste gate would open before reaching target boost.
      11-19-2019, 08:23 PM   #3
paimon.soror
paimon.soror's Avatar
629
Drives: 2016 F36 435x MSport
To heat up the cats. Stock tune opens the WG on cold start for emissions compliance
      11-20-2019, 07:30 AM   #4
CandyRedRC46
242
Drives: 2013 328i
interesting. well that would be a cool feature to have.
      11-20-2019, 11:35 AM   #5
Zabiz
Zabiz's Avatar
20
right!! Hear that turbo spool on cold start, I have bootmod3 so I might ask them if they have any plans on doing something like that
      11-21-2019, 01:56 AM   #6
ProjektAutoScott
ProjektAutoScott's Avatar
66
Drives: 2021 M340i
BM3 should have a provision for a “cold start delete” if I recall. That may keep the waste gate shut, or it may not. Worth a shot if you are catless. Otherwise there may be slight risk of damage to your cat. Not sure how much open WG matters, but it definitely has a purpose.
      11-23-2019, 10:28 AM   #7
rjd_F30
rjd_F30's Avatar
2000
Drives: 2013 335i 6MT
The cold start delete only lowers the rpm on startup so the car just starts right to idle speed. Doesn't do anything with the waste gates.
Instagram: rjd_f30 | Current: EBII 2013 335i 6MT RWD & Sprint Blue 2008 Audi RS4 | Retired: 2013 328i, 2000 XTerra, 2022 Civic Si |
      11-25-2019, 08:53 AM   #8
CandyRedRC46
242
Drives: 2013 328i
It does a little more than just idle RPM. The factory cold start setting actually retards the ignition timing a lot, to put an artificial load on the engine to raise EGTs enough to heat the cat up quickly. The timing is pulled so far back that a lot of combustion is occurring outside of the engine (to heat the cat up), hence why cold start is so obnoxiously loud. It is probably doing some adjusting to the vanos and valvetronic as well.
Appreciate 2
rjd_F301999.50
Zabiz20.00
      11-26-2019, 01:36 AM   #9
rjd_F30
rjd_F30's Avatar
2000
Did not know that. Thanks for making me a bit smarter
However, in the context of the waste gates opening or closing, the BM3 cold start delete is still irrelevant.
      12-05-2019, 08:56 AM   #10
Zabiz
Zabiz's Avatar
20
That is so cool hahaah, thank you for that info! I'm just guessing that bmw uses a different cold start route compared to the Mercedes to heat up the cats, also the benz is twin turbo so I'm not sure, also could be that the injectors are too loud to hear any spool
f30post
