BMW X5
      11-12-2019, 06:49 PM   #1
ted920
153
Drives: 2019 BMW X5 40i, Lexus GS 300
21 All Season 275/40/21 on all 4 corners
I just talked with Tire Tack and they said I can do 275/40/21 (the stock front size) on all 4 corners. He said the tire will fit a wheel from 9-11" wide.
Im reaching out to fellow Bimmerposters to confirm if this will work (winter setup) and not cause any problems. He said the rolling diameter is exactly the same.
He found a really good snow rated all season tire for me at a great price.
I look forward to your feedback.
      11-13-2019, 06:06 AM   #2
Kief
Kief's Avatar
4427
Drives: '24 iX50; '23 i4 M50
Im reaching out to fellow Bimmerposters to confirm if this will work (winter setup) and cause any problems. He said the rolling diameter is exactly the same.
Yes, it will work. I did the same for my current M3CS 255/35/19 19x9.5 on all four corners.
'24-I20 iX 50; '23-G26 i4 M50; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired
      11-13-2019, 09:40 AM   #3
ted920
153
Thank You - its much appreciated.
      12-05-2019, 08:18 PM   #4
Thumbs
28
Drives: '01 X5 3.0 5-spd, '10 X6 i35,
The U.S. fitment with the M740 wheels is 9jx20" at all four corners with 275/45/20 tires. Having a tire that can go on 9" and 10.5" wheels allows front/rear tire rotation which can't be done with the staggered tires.
      12-06-2019, 12:04 AM   #5
TXPearl
53
Drives: 2024 X5 M60i
Even though the tires are the same size, I'm not sure about rotating an 10.5" wide wheel to the fronts on an X5. The extra 1.5" of wheel has to go somewhere. The wheels may have a different offset front vs. rear.
      12-07-2019, 10:59 PM   #6
spike5150
421
Drives: 2020 X5 M50i
I think he is saying he wants to use stock staggered 21” wheels with square setup all season tires.
If the tire will fit the rim, then it should work.
OP - you could rotate the tires between wheels if you wanted that benefit.
      12-08-2019, 09:45 AM   #7
Auricom
Auricom's Avatar
4357
Drives: 2020 X5 xDrive40i M Sport
I agree... though that sounds like costly maintenance over time.
Bonus would be always having balanced wheels
Current BMWs - '20 X5 xDrive40i M Sport, '20 BMW M550i | Past BMWs - '03 E39 540iT M Sport, '06 E53 4.8is, '11 E70 M Sport LCI
      12-10-2019, 03:40 PM   #8
vinnymac
157
Drives: 2024 X5 50e
275/40/21 on all four corners works. That what I run as my winter tires on the OEM 741 wheels that came on my X5 40i.
      12-12-2019, 01:35 PM   #9
ted920
153
I am doing the exact same thing and everything is going perfectly.
Got a great deal on Vredestein tires that are good in winter / snow.
This is exclusively a Winter set-up.
      12-16-2019, 09:00 PM   #10
jxterma
Drives: 2012 x3 35i
Good to know! I just picked up my X5 on 741M wheels. Will probably do the same for winter. Just to confirm, do you all have m-brakes?
      12-17-2019, 07:27 PM   #11
ted920
153
Yes, M Brakes.
Runs PERFECT!
Ftpohyeah284.00
      12-27-2019, 11:27 AM   #12
Ftpohyeah
Ftpohyeah's Avatar
284
Drives: BMW
2022 X3 M Competition  [0.00]
2024 BMW  [10.00]
Fantastic!
Will get a set of michelin pilot alpin 5s for winter.
      12-31-2019, 03:45 PM   #13
alpinekarthik
alpinekarthik's Avatar
106
Drives: X5
Everyone, I am looking for a similar set-up for my 744 Orbit Grey Y-Spoke 21"
I am not able to find a winter or A/S tires on tirerack of the same size to go all 4 corners. It looks like the same size as 275/40-R21. Can someone please let me know what tires they are referring to?
      12-31-2019, 04:07 PM   #14
Auricom
Auricom's Avatar
4357
Here's the front Pirelli Scorpion Verde 275/40R21 A/S:
https://www.tirerack.com/tires/tires...ty=2&tab=Sizes
And the rear 315/35R21 A/S: $$$$
https://www.tirerack.com/tires/tires...135VR1SVASXLN0
Front Pirelli Scorpion Winter 275/40R21
https://www.tirerack.com/tires/tires...m=74VR1SCORWXL
BMW sells the Scorpion Winter rear tire only with the winter wheelset and I'm unable to locate the 315 for the rear on TR. You can run the same size winter front on the rear.
Here's the Michelin Alpin 5 SUV snow tires:
https://www.tirerack.com/tires/tires...4VR1PA5SUVXLN0
Appreciate 2
      12-31-2019, 04:17 PM   #15
alpinekarthik
106
Drives: X5
Thank you! For some reason when I spoke to the tirerack about the the Scorpion Verde All Season they said it's meant for Porsche and that's why it doesn't show up for X5.
Is it safe to assume I can do the staggered set-up with Pirelli Scorpion Verde even though it shows up as not compatible for X5?
Please see attachment
      12-31-2019, 04:24 PM   #16
Auricom
Auricom's Avatar
4357
I'd run a square winter set just for this trip. The 275 will fit on the 10.5 - not ideal but it'll work - and figure out a longer term solutiom for A/S when you're closer to replacing the stock summers.
Porsche N0 designation on tires means it Porsche tested and approved. When I sold tires decades ago, I'd recommend to customers not to mix tire since the tread pattern could be slightly different, rubber compound etc.
As long as the sizes match up to what's on your vehicle, you're good. It's one of the reasons why I shy away from 21s on my G05 know what a PITA it is to find tires for it.
      12-31-2019, 04:30 PM   #17
alpinekarthik
106
Drives: X5
Thanks for your time on this!!
      02-01-2020, 01:24 PM   #18
araje
59
Drives: BMW, Audi
Auricom I am trying to understand your response but I have to admit I am not a pro in tires. Can you explain what is the 10.5 you are talking about.
This thread is really helpful since I will be on 21" style 744 stock Perf RF on staggered build.
In my quest for A/S, I liked the Pirelli Scorpion Verdes and almost finalized it until I figured that they are non-RF.
I am ready to go for a square setup if I can find A/S RF. But then trying to understand your above response why it is not ideal.
Any info you can provide will really help.
      02-01-2020, 01:28 PM   #19
LexxM3
LexxM3's Avatar
1698
Drives: E46M3, G05X5
2019 X5  [0.00]
10.5 is referring to the width of the stock 741M REAR rims (10.5 inch).
G05 X5 x40i (04/2019 mfg, Canada) on S18A-19-11-540
      02-01-2020, 01:39 PM   #20
Auricom
Auricom's Avatar
4357
Staggered setup
When you option 21" or 22" wheels, the front and rear tires (275 front and 315 rear) in addition to the front and rear wheels are different widths - 9.5" front and 10.5" rear.
Square setup
On the 20" the front and rear tires are the same size and widths (275 front and rear) with 9.5" wide front and rear wheels.
Tire widths have a recommend wheel width range as to not pull the tire mounting too far in (smaller than recommended width) or stretching it too wide (larger than recommenced width).
Here's a visual.
      02-01-2020, 04:59 PM   #21
araje
59
Drives: BMW, Audi
Ah like they say, a picture is worth a thousand words.
Thank you so much for this explanation.
So basically to do a safe square setup I would have to not just do 4 x 275 tires but will have to buy 2 extra front wheel rims to mount on the rear and then shop for 4 x 275 tires which are A/S RF.
Thanks so much for the great explanation.
      02-01-2020, 05:26 PM   #22
Auricom
Auricom's Avatar
4357
You can run 275s on 9.5 front and 10.5 rear wheels, it's not ideal but it'll work - 275s will fit on the 10.5. You just won't be able to rotate the tires without remounting and balancing. You can find staggered all seasons for your vehicle - which would be my recommendation.
It's up to each owner to asses how much investment they want to put into managing their tires beyond OEM.
Search this Thread:
Advanced Search
xbimmers
