Manual to Auto ?? 3.08 Ring/Pinion With Helical Limited-Slip Differential
11-11-2019, 09:05 PM | #1 |
Rep 61
MF-TRS-05E9230KT
Here is the exact item that is on the manual 335i https://www.ecstuning.com/b-team-mfa...BoCe7MQAvD_BwE 3.08 Ring/Pinion With Helical Limited-Slip Differential This is off a manual 335I can i get this to work on a 335I automatic? |
11-11-2019, 10:14 PM | #2 |
114
Rep 598
Ring and Pinion is what decides your final ratio. If you're rocking RWD, just slap it on and go. It will make difference between your indicated speed vs real speed.
But BMW comes with that OE already with 6.4% difference on mine, lol. Maybe it will fix it. You can also save money, get the diff for $750 on eBay etc, pop it into your open diff or similar open diff for dirt money off eBay (to reduce down time). You will need to adjust and ensure gear lash is good. Take it to a shop. |
11-12-2019, 05:50 AM | #3 | |
Rep 61
Thanks they guy is offering it at a great price for less than half on ECS pricing. |
11-19-2019, 10:05 AM | #4 | |
476
Rep 1,191
Drives: 2009 BMW 328i Wagon
11-19-2019, 10:44 AM | #5 |
114
Rep 598
11-19-2019, 12:12 PM | #6 | |
476
Rep 1,191
Its a tool you can use to calibrate your speedometer without fucking with your odometer, like you would if you were to use tire size. You can also use it to make your MPG gauge into an oil temp gauge. |
11-19-2019, 01:57 PM | #7 | |
114
Rep 598
I'll check out the speed. It's still 1% off even with 235/45/18 tires 😃 Bimmer Code and Carly apps couldn't do it on US cars. |
12-29-2019, 01:35 PM | #8 |
87
Rep 236
Drives: e92 335iA
MT 3,08 v. 3,46 AT is some 12% difference...
I’ve went from 2,93 to 3,15 (manual and lighter chassis though), it was just easier to drive out from a dead stop, not a game changer... The same later on when I changed the diff from 3,15 to 3,23... minor performance gain, more acceleration, higher revs at given speed on a highway... I think it won’t be a huge gap to give you any technical issues... apart from possible mismatch of values in rpm/speed tables for AT... I know from other platforms that modern Bmw check those values, I am not sure about e9x...
"If everything seems under control, you're not going fast enough.” Mario Andretti
