11-09-2019, 03:36 PM | #1 |
27
Rep 55
Are the proximity sensors disabled in Sport/Sport+ ?
As the title reads, are the parking sensors disabled in the sport modes? Often when I arrive at home with the car in Sport+ and park in my driveway nose first I will get no proximity warning as I approach my closed garage door.
I did notice that if I pull in to the driveway and put the vehicle in reverse, the sensors / warnings will come on and stay on if I return the transmission to Drive.
2018 340i X-Drive | M-Sport | MPPSK | Dinan Intake
11-09-2019, 03:51 PM | #2 |
2966
Rep 6,003
It's on when you put it in reverse but not when you pull in while in drive regardless of mode. When you put it in D from R it stays on for a few feet moving forward before turning off. Does not matter what mode it will come on whenever you are in reverse even in sport plus. It's required by law to do that.
Kaisah71.50 |
11-09-2019, 05:01 PM | #4 |
27
Rep 55
Oh okay, weird... Thanks guys, my previous vehicles all had the front sensors active below a certain speed threshold regardless of forward or reverse gear.
11-09-2019, 05:04 PM | #5 |
2966
Rep 6,003
Yes I do wish the sensors were on at all times like when pulling in that it will pick up if you're getting too close or parallel parking where you don't use reverse. I've put the car in reverse to get them on sometimes before pulling forward.
11-09-2019, 05:20 PM | #6 |
8245
Rep 16,088
One reason they're not active unless you put the car in reverse or you manually engage the rear camera is so they won't sound off when in congested city traffic. From a technical standpoint they work in tandem with the rear camera, so you can't have the one without the other.
11-09-2019, 05:37 PM | #7 | |
1599
Rep 3,748
11-09-2019, 05:41 PM | #8 | |
27
Rep 55
I'll never need them during regular driving, only when trying to park within a few inches of something I don't mind having the consistency of a warning system. I'll just have to get used to turning them on myself!
11-09-2019, 05:56 PM | #9 | |
72
Rep 266
VW/Merc/Audi all have auto front sensors and in my experience with those cars they don't go off in traffic. Or in the drive through. They just come in when your slowly approach something very close. I rarely sat that close to someone's bumper in traffic.. BMW even have auto front sensors in X cars... so they can do it. Just not on F series cars. Not sure if the G series has it? But it's definitely not because of the traffic thing.. |
11-09-2019, 06:14 PM | #10 | ||
1486
Rep 1,268
11-09-2019, 09:35 PM | #11 |
8245
Rep 16,088
There's only one way to know if those on an F30 would go off in traffic, that being if you coded your rear camera/PDC to be able to be activated at any speed, and to remain on until one turned them off. I did. If left on they will go off in city traffic, annoyingly so.
11-09-2019, 09:55 PM | #12 |
171
Rep 257
Mine stay on in sport. And they will warn you in traffic, if you are willing or brave enough to pull up close to the rust bucket in front of you.
The BMW is the first car I had with front sensors that warn you to a low parking lot curb when you pull into a parking space. It hasn't failed to do so yet, and I haven't scraped the underside on a curb yet either. (Knock on wood) I say, so far a good front PDC system. Other cars warn of a bumper or a wall, but never a low curb.
2021 i3s AC Schnitzer BMW CCA #67486 |
Lance_Goodthrust4.50 |
11-10-2019, 12:53 AM | #13 | |
poopycat
266
Rep 791
Yes, I know tapping a button is hard in this day and age. |
11-10-2019, 02:45 AM | #14 | ||
72
Rep 266
11-10-2019, 02:48 AM | #15 | |
72
Rep 266
I'd you manually override and turn them on then of course then will go off as soon as you get near to something. That's different to how automatic PDC works. Even under the BMW marquee. Not trying to cause an argument here but the system works flawlessly in other cars within the BMW range as well as other marquees. Surely they could have turned this ok in the Fxx: minor annoyance but takes some getting used to when you're used to it being auto. |
11-10-2019, 06:16 AM | #16 | ||
2966
Rep 6,003
11-10-2019, 06:27 AM | #17 |
1890
Rep 3,877
The front PDC sensors on the F3x ARE active all the time and WILL signal you if you get too close to an object in the front!
I intentionally get close to some bushes when maneuvering to park at my place, as this automatically activates Surround view and the vehicle remains in surround view when you then put in reverse. Otherwise putting in reverse activates the rear view camera only and I need to manually go to Surround view if I want that. Or I need to press the park button before I put in reverse. What I don's know however is whether this exact logic and activation applied pre-LCI.
"Large increases in cost with questionable increases in performance can be tolerated only in cars and women."
11-10-2019, 06:31 AM | #18 | |
2966
Rep 6,003
11-10-2019, 06:57 AM | #19 | |
25
Rep 110
11-10-2019, 07:44 AM | #20 | |
72
Rep 266
11-10-2019, 07:44 AM | #21 | |
poopycat
266
Rep 791
No they are not, you have to actively turn on PDC on a 2017. In my garage I have limited space, my tool box is larger and weighs more than the F3x, but when I get close, nope. I'm about 11 cm from it right now, just hating the day I actually tap it. |
11-10-2019, 07:48 AM | #22 | |
poopycat
266
Rep 791
Lucky you. Grap the vw forums asap then. New 2017+ have sporadic sensor confusions galore, and sunroof leaks, and blown engines, and awd failures. I'm sure I'm missing a lot here. VW is a mess these days. Thanks for playing! |
