11-07-2019, 06:07 AM | #1 |
1340
Rep 1,240
How "close" do overall diameter tires need to be?
Currently researching a staggered wheel/tire setup.
Absolutely want to go with a 22x12 on the rear. I don't want to compromise on that. For the front, I'm not as picky... I can go with anywhere from 9" to 10.5", so long as the offset is appropriate.... but I can determine that later. The problem isn't finding tires.... the problem is finding MATCHING BRAND tires... and if not, exactly how much "difference" can there be between the overall height of the front tires for the front vs. the rear. For example... 22x12 rear wheel, 335/25/22 tires, 28.6" overall height. 22x9.5 front wheel, 275/30/22, 28.5" overall height 22x9.5 front wheel, 265/30/22, 28.3" overall height 22x10 front wheel, 285/30/22, 28.7" overall height 22x10.5 front wheel, 295/30/22, 29.0 overall height I think that ".1" height difference is likely ok... maybe even ".4" would be ok.... but exactly how much difference does the manufacturer allow for, without potentially damaging the drivetrain? My "best guess" so far... is a 22x10/12, with 285/30/22 front and 335/25/22 rear. Front tires would be Toyo Proxes 4 (28.7"), Rear tires would be Toyo Proxes STIII (28.6"). That's about as "close" as I can get, and while they aren't the same "exact" tire, at least they are the same "brand"???? But... Definitely willing to hear recommendations, or successful similar setups from the past.
2020 X5 M50i, Alpine, B&W, Air Susp, anthracite, coffee, **CD player**:
15+ PAGE BUILD THREAD:https://g05.bimmerpost.com/forums/sh....php?t=1694019 690HP / 928nM Dynotune:https://g05.bimmerpost.com/forums/sh....php?t=1729813 6-Piston/4-piston BBK:https://g05.bimmerpost.com/forums/sh....php?t=2097342 Last edited by Ninefourteener; 11-07-2019 at 06:37 AM.. |
11-07-2019, 10:37 PM | #2 |
422
Rep 982
Excellent question. I can add some real world insight. On my F15, my rear tires had worn down to 2/32”, while the fronts were down to 6/32”. This translates to 0.25” diameter difference. I experienced no issues as a result of this.
11-08-2019, 08:19 AM | #3 |
1340
Rep 1,240
Sooo... upon further research.... I've discovered the most commonly used "aggressive" wheel and tire combo is a:
22x10.5 Front, ET 35 22x12 Rear, ET 25 front: 295/30/22 rear: 335/25/22 Both sizes are available in Toyo Proxes STIII, which are a decent all-season, reasonably priced, and they match, and you don't have to buy cheap junk like "Lexani" or "Lionhart" tires from China. It's about a .4 difference in overall height, but I have to assume because that is what everyone is using, that it's ok. That is EXACTLY the setup this guy is using.... and I specifically chose this one, because it's not an "X5M" that sits lower. https://www.bcforged-na.com/project/...-x5-22-hcs21s/
15+ PAGE BUILD THREAD:https://g05.bimmerpost.com/forums/sh....php?t=1694019 690HP / 928nM Dynotune:https://g05.bimmerpost.com/forums/sh....php?t=1729813 6-Piston/4-piston BBK:https://g05.bimmerpost.com/forums/sh....php?t=2097342 |
11-12-2019, 07:04 AM | #5 | |
1340
Rep 1,240
However, running a smaller or larger rolling diameter on the front vs. the rear, can cause problems with the transmission.... that is ultimately what this post was about.
11-12-2019, 09:30 AM | #6 | |
1053
Rep 1,951
11-12-2019, 12:53 PM | #7 | |
1340
Rep 1,240
Which meant, if your tires were 50% worn, and one got destroyed..... you had to buy 4 new ones. However.... that was a full time, 50/50 drive, manual transmission. I can understand why tolerances were so low. My new X5 will have an automatic transmission (fluid driven, not gear driven)... plus the ability to xfer 100% of the power to the rear wheels... so I have to assume there has to be considerably more "flexibility" in the X5. But I'm certain there has to be a "limit". I seriously doubt you can run 30" drag radials in the back, with a 13" skinny up front Not that you'd want to, but you know what I mean But... I'd like to read some sort of BMW documentation that specifically addresses this topic. |
11-12-2019, 01:37 PM | #8 | ||
1053
Rep 1,951
