11-06-2019, 08:36 PM | #1 |
68
Rep 698
Code P11C5? Any info on this will help , tia!
I have a 2013 328i n26 with a bms stg 1 only had it for a year at 90k miles now, i was heading to work when all of a sudden cel came on i have my 40 dollar scanner which says its p11c5 ive tried researching and only states its a camshaft position sensor? Cylinder 4?
Can anyone help with some info if any on this? |
11-06-2019, 08:41 PM | #2 |
2466
Rep 5,457
Drives: F30
Differential pressure sensor, tank vent valve, electrical: Short circuit to ground
The diagnosis monitors the suction jet pump differential pressure sensor at the tank ventilation. Fault monitoring conditions: The fault is detected if the pressure sensor voltage is less than the following limit value: 0,2 V Check lines and plug connections between the following components: -DME - Suction jet pump differential pressure sensor Replace differential pressure sensor. |
11-06-2019, 08:57 PM | #3 | |
68
Rep 698
