11-06-2019, 04:12 PM | #1 |
53
Rep 251
335d xdrive into drive without applying brake??
Hi,
I have recently bought a 335d xdrive auto. So far I am very pleased. My only gripe is that I find it extremely frustrating that I have to apply the brake to put the transmission into drive from neutral. This isn't an issue if I am completely stationary. But if, for example, I am approaching a red light and I select neutral from drive and almost coast to a stop but then the light turns green I should be able to press unlock on the selector and engage drive to pull away. It seems silly that I have to press unlock and have foot on the brake. Surely just pressing unlock should be enough. Is there anyway to switch the footbrake unlock off? |
11-06-2019, 04:45 PM | #3 |
2966
Rep 6,001
danperson165.50 |
11-06-2019, 04:55 PM | #4 |
516
Rep 1,452
I don’t think an automatic was meant to be put into neutral to coast to a light. Especially these days. I don’t see the reasoning behind it. It may be a safety thing. Especially with the shift lever,you could end up in reverse. I think more damage could be done by going from neutral to drive while moving than any perceived thing you think you are saving.
Moonstone710.00 |
11-06-2019, 05:00 PM | #5 | |
2966
Rep 6,001
11-06-2019, 05:41 PM | #6 |
53
Rep 251
11-06-2019, 05:56 PM | #8 |
2025
Rep 2,805
Drives: F33 430 and F39 M35i
Drive in eco pro so it coasts for you.
Who taught you to drive that way on an automatic? |
11-06-2019, 05:59 PM | #9 | |
53
Rep 251
I'm talking about at crawling speeds so car stability isn't really an issue here. |
11-06-2019, 07:17 PM | #12 | |
53
Rep 251
https://discover.bmw.co.uk/technolog...rgy-management Whenever the driver takes their foot off the accelerator without braking, the Coasting function (part of ECO PRO mode) cuts the power between the engine and drive in vehicles with an automatic transmission. The vehicle rolls along without any resistance from the engine, which rotates at idle speed consuming minimum fuel and with low emissions |
11-06-2019, 07:27 PM | #13 | ||
4488
Rep 10,473
11-07-2019, 03:50 AM | #14 | |
6659
Rep 15,858
BTW, there's the OP's initial question and slightly different direction running in the UK section of the forum. https://f30.bimmerpost.com/forums/sh....php?t=1667127 These 'dual' posted topics make it more difficult to keep up with and understand the OP's real issue. |
11-07-2019, 07:14 AM | #15 |
48
Rep 162
I've wondered about this as well. More nagging; is there a way to code-out the UNLOCK button on the side of the shifter? This button is a redundant step since the brake needs to be applied anyway.
11-07-2019, 09:08 AM | #16 | |
629
Rep 965
Drives: 2016 F36 435x MSport
Street driving, you will waste more gas constantly popping to neutral. same principals as driving a 6MT
2010 Mazda RX8 - Sold (11/17)
2016 BMW 435xi GC - Current |
11-11-2019, 11:48 PM | #17 |
Great Teacher
1088
Rep 1,305
Drives: 06 e91 325ix
In the good old days BMW would use 0 gas ie 0 injector dwell when actually engine braking.
But that was bad for the torque converters or something I am sure, so we get unlock clutches and coast in eco pro. And it is all I use eco pro for. Coasting down offramps |
