11-04-2019, 06:21 PM | #1 |
Boost Addict
334
Rep 349
*Newer* CDV Delete Method (Easier Way!)
*Newer* CDV Delete Method (easier way)
Hey guys, so did the original CDV delete by drilling the restrictor out, but after a year-ish I started leaking brake fluid from the slave-line connection. I think its the o-ring on the hardline that’s leaking but could also be the modified slave too…So I decided to try another route. The E90 Slave looks exactly the same, and as we all know the E-series BMWs came with an external CDV. So I went to FCP and got a new E90 Slave + new F30 hardline (I assume is the leaker). E90 Slave P/N = 21526785964 The F30 lines connects right in!!! Result/Review: The clutch is now exactly how my E82 or E30’s felt! If you’re a 3rd pedal geek, this should be the mod for you. Easier than the drill method, just buy and install. For the guys who have done the drill method like me, this new slave is a bit better than the drill method. I am now WOT slamming and banging gears with zero slip. Install pics & details:
S55 M2C | Three Pedal Club | E30TU
16
kern4174449.50 akgambino271.50 upsidedownfunnel1999.00 250gtcalifornia0.00 Fliplegend1471.00 MacklinUSOB518.00 Poochie9104.50 VisualEcho6636.50 MLJR235116.50 AndrewC198910931.00 dbright0377.00 ronanz1819.50 DLag30103.50 zinner559.00 esoj37156.00 EBII33533.50 |
11-05-2019, 04:03 PM | #3 |
5556
Rep 5,372
Very nice. Thank you for discovering and posting this.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
11-05-2019, 08:20 PM | #4 |
245
Rep 2,387
I admire your efforts! I completely removed the cdv (not just drill out the restrictor) and haven't had a problem with leaking fluid. The cdv has nothing to do with leaking fluid. Are you sure you had a solid connection between the hard and flexible lines?
2016 340i XDrive, EBII/black, 6 MT, M Sport, Track Handling, Cold Weather, Tech, Lighting, Driver Assistance Plus.
2012 Z4 35i, ED 2/24/2012, Melbourne Red Metallic, Black Leather, Carbon Trim, 6MT, M Sport, CW, PP, PS, NAV, CA. |
pkiledj46.00 |
11-06-2019, 08:02 AM | #5 |
E4 Mafia
325
Rep 412
Drives: E30, E36/5, E46, F22, F30
Garage List 1990 BMW 325i [0.00]
1998 BMW 318ti [0.00] 2003 BMW 325i [0.00] 2015 BMW 335i [0.00] 2015 BMW M235i [0.00] |
E30? this makes the clutch feel like an E30?!?! thank you for posting this, it's gonna move to the top of my mod list!
Squad - '90 E30 325i MT (225k) | '98 E36/5 318ti MT (153k) | '03 E46 325i MT (152k)| '15 F22 M235i MT (60k) | '15 F30 335i MT (80k)
KIA - '91 E30 325i AT (146k) | '02 E46 325i MT (212k) Bring back the purple M stripe |
11-06-2019, 02:03 PM | #7 |
989
Rep 2,200
Any idea if a 2015 228i manual has this & if this modification would use the same part? Thanks in advance!
____________________________________________
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system, Blue Metallic Matt Accent Moldings, Aluminum Hexagon Interior Strips, Anthracite Headlining |
11-07-2019, 12:16 PM | #8 | |||
Boost Addict
334
Rep 349
This P/N is also on E-series N20 engines, so I would assume it will work too. Its only $60 to find out.
11-07-2019, 02:54 PM | #9 |
518
Rep 891
This is the sexiest post I have seen in a while, nice work.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
11-07-2019, 08:10 PM | #10 |
86
Rep 174
Drives: 2014 F32 435i xdrive 6 speed
11-08-2019, 12:02 PM | #12 | |
Boost Addict
334
Rep 349
The Wobble Bar is definitely the most useful ratchet attachment Ive ever used. In most situations the swivel joint is too much articulation and PITA with the binding. It really is easy, took maybe 30mins max, and I am not even a weekend warrior wrencher. But any shop can do it, just get the $60 part and ask them to install, would be easy money for them.
11-08-2019, 04:25 PM | #13 |
E4 Mafia
325
Rep 412
OK. I took my E30 for a joyride yesterday and drove my F chassis to work today. Whole time i couldn't get your thread out of my head.
Just to check, your old slave cylinder was 21526795713? The diameters on realoem are exactly the same, just want to be sure! Also, the hard line you just replaced because of your leak, otherwise, we probably wont need it? At $60, i am guessing you got the FTE.
11-09-2019, 04:00 PM | #14 | |
Boost Addict
334
Rep 349
I just got the FTE, its a good brand. And correct, I suspected the line O-ring to be faulty so I just got a new line too, which is not needed in your guy's case.
12-18-2019, 02:42 PM | #15 |
10931
Rep 4,551
Drives: 2015 328d xDrive
Will this work on the OG M2?
12-18-2019, 06:14 PM | #16 |
Luxury at the redline :)
9105
Rep 7,563
Hey,
I verified the F30 335i uses the same slave cylinder as the F87 M2. Also, it's the same exact size and PSI as the E92 335i (No CDV) So you good to go, just don't forget a review . |
AndrewC198910931.00 |
12-18-2019, 11:01 PM | #17 |
10931
Rep 4,551
12-18-2019, 11:30 PM | #18 | |
9105
Rep 7,563
Yes, from what I see, that's the latest part number. If you order it in person, just tell them you want that part or whatever supersedes it. From what I understand, whatever part number you give them, they receive the most recent revision of that part, even if it's not the same number. Same core product just new for whatever small reason, from price to distributer. |
12-19-2019, 12:03 AM | #19 | |
10931
Rep 4,551
Poochie9104.50 |
12-23-2019, 12:49 PM | #20 |
117
Rep 243
Just finished up this install using the exact instructions put forth by the OP. Doing the reverse bleed method is a must and fail-proof way to effectively bleed your clutch line 100%. YOu will need a syringe type device to do it but it is well worth it, TRUST ME! lol.
Results are just as advertised. Off the line starts are way more predictable and honestly, the clutch feels "correct" now. No more hit and miss engagement points which are more annoying than words can express. ANyway, this a must-do mod for anyone who has ever had second thoughts as to why they got the manual trans on their late series bimmer. Cheers OP you deserve it |
Tchao333.50 finagansbmw45.00 |
12-23-2019, 05:21 PM | #22 |
Boost Addict
334
Rep 349
All recent BMW Slaves are plastic now.
Littlebear3509.50 |
