Twisted Front End Links - ST XTA Coilovers and Whiteline sway bar
11-03-2019, 08:35 PM | #1 |
11
Rep 37
Hello all,
I'm looking for some advice on the issue im having. See photos of twisted end link. This is the same on both sides after upgrading to ST XTA coilovers and a whiteline front sway bar. I've only lowered about 1 inch, maybe 1.5. The height is right in the middle of the range for the coilovers. Before purchasing, i called ST to ask them if I'd need adjustable end links, they said no. Supposedly the end link mounting point on the shock body was designed to accommodate lowering. Although this was specifically an answer if keeping the OEM sway bar. I have compared the whiteline bar and the OEM, the dimensions look pretty damn close on the whiteline, so I doubt its an issue with the sway bar. So have I done something stupid on install? Or do I just need to get adjustable links? |
11-04-2019, 06:38 PM | #3 |
11
Rep 37
Ya, thats the conclusion Im reaching. How do I determin how long they need to be? I see several options available for the E92, but they all seem to have the same base length as OEM, 11.5".
I've seen another post where someone discusses the Whiteline adjustable links and says they are 12.5" out of the box, but according to whiteline tech support, they are 290mm, or 11.5 inches. Any recommendations on a product? |
11-04-2019, 06:55 PM | #4 | |
2183
Rep 2,806
Maybe just placebo effect, but, they seem to have really helped flatten out the car in cornering.
E82 / BMWP Springs / Koni Yellows / M front control arms / Adjustable front endlinks / M rear guide rods / Whiteline Poly RSFB
Stevesmokeman10.50 |
11-05-2019, 06:37 AM | #5 |
45
Rep 163
The ARB drop links are handed.
Lemforder parts: 35364-01 LH https://webcat.zf.com/nc2_teile_info...EINSPNR_ART=35 35365-01 RH https://webcat.zf.com/nc2_teile_info...EINSPNR_ART=35 Have you fitted them to the correct sides? |
11-05-2019, 12:35 PM | #6 | |
4276
Rep 9,206
11-07-2019, 07:16 PM | #9 |
11
Rep 37
Well, add this to the saga of noobism. I had the sides mixed up. I have laid under my car for hours trying to figure this out, so thank you stevesingo for pointing out the obvious to me.
To top off my noobism, I immeditly purchased a set of adjustable end links after the first two comments to this thread. But i swapped the OE Myle links last night and everything fits perfectly, lenght is just fine. So now I have an extra set of unused, un-needed whiteline adjustable end links! PM if you need a pair! |
11-07-2019, 10:42 PM | #10 | |
2183
Rep 2,806
https://www.e90post.com/forums/showthread.php?t=1523326 And don't feel bad for a screw up. Everybody has at least 1 to their credit. If someone says they don't, they are fibbing.
11-08-2019, 02:43 AM | #11 | |
45
Rep 163
I only knew of this as I refurbed my suspension a few months back and after fitting one drop link I noticed that it didn't look right. I figured it out when I got the other out of the wrapper and placed it along side the one I had fitted. Easily done. |
11-09-2019, 11:41 AM | #13 | |
4276
Rep 9,206
11-09-2019, 11:53 AM | #14 | |
2183
Rep 2,806
If the car lowers at highway speed or loaded, the standard length are just that much more less than perfect. Anyway, why not start out as close to optimal as possible? They aren't too pricey ~ $120.
11-09-2019, 12:03 PM | #15 | |
4276
Rep 9,206
11-09-2019, 12:10 PM | #16 | |
2183
Rep 2,806
Seriously, in moderate corners and turns I think the car feels flatter. Maybe just justifying the expense and time, but I've thrown away money in more silly ways.
Tags |
adjustable, end links, st coilovers, st xta |
