11-01-2019, 09:38 PM | #1 |
14
Rep 19
BimmerCode Update ICM expert mode: F30 Enable sport+ mode and Driving Mode Config
Hey everyone, with BimmerCode's latest iOS update enabling ICM Expert Mode, you can do two new things now:
1. See Sport+ option on Combi Screen when switching modes (before Sport+ wouldn't show as an option when switching; it just appeared there after you clicked sport mode twice). In Expert Modes: KOMBI => 300C ECO_FDS => FDS_MENUE_TEXT_1=> menue_3 FDS_MENUE_SIGNAL_1=> menue_3 FDS_MENUE_TEXT_2=> menue_3 FDS_MENUE_SIGNAL_2=> menue_3 FDS_MENUE_TEXT_3=> menue_3 FDS_MENUE_SIGNAL_3=> menue_3 FDS_MENUE_TEXT_4=> menue_3 FDS_MENUE_SIGNAL_4=> menue_3 FDS_MENUE => menue_3 (This will add Sport+ as an option when you are adjusting modes on your Combi Screen) ICM => 3000 Daten => IcmKod_B_Sportlenkung => verbaut EGS => 3000 Applikation => Sportschalter_alt => aktiv 3000 Applikation => Sportschalter => aktiv 2. Enable Driving Mode Configuration for Sport Mode (you can now have Sport Mode with the heavy steering and Comfort Transmission/Throttle, vice-a-versa, or all sport). In Expert Modes: HU_CIC => MACRO_FDS => popup_config ICM => KOD_B_SPORTINDIVIDUALISIER => ein (1) Last edited by dexterdpc; 11-02-2019 at 10:49 AM.. Reason: correction |
11-02-2019, 07:14 AM | #2 |
43
Rep 121
I had been waiting for expert mode access for the Integrated Chassis Management ECU so I could code the LIM function in my F31. Now what used to be the cruise control Set button calls up LIM - you can set a maximum speed (e.g., for in-town driving). There is additional resistance from the throttle as you approach the set speed. You can push through this to accelerate beyond the set speed. "Limit" and the set speed show up in green in the HUD; "Limit" blinks when you go beyond the set speed. Turning cruise control on turns LIM off.
KOMBI 3003 SLD_Enable -> aktiv ICMQL 3000 SLD_Funktion -> aktiv ICMQL 3000 C_Umschaltung_ACC_DCC -> zugelassen |
dexterdpc13.50 |
11-02-2019, 10:54 AM | #3 |
14
Rep 19
Yeah - that worked great. It cuts off the fuel when you hit that set MPH and you can turn it on even when you're stopped. Thanks!
