11-01-2019, 08:46 PM | #1 |
21
Rep 26
New owner of a 2013 335i Sedan w/ 70k miles
Hello everyone. I've been lurking around these forums for a while, and I just purchased a 2013 Black Sapphire Metallic 335i two weeks ago. See pics attached below.
This is my first BMW. I come from an Infiniti G37 sport package sedan. So far I really like my 335i, and I plan to keep it for many years way past 100k miles. I'm not much of a DIY guy, but I am big on preventative maintenance. I already found an independent bmw shop in my area that I like. This car hasn't been in any accidents and has had regular oil changes, and service at the dealer. There are no oil leaks. This car is fully loaded with the heads up display, Harmon kardon system, cameras, etc, except it's missing the paddle shifters and the sport seats w/ the thigh extensions which I really wish I found. But this car does have the black interior I wanted. Apparently my car has the M sport blacked out kidney grill, and 18" M sport wheels which is cool. I'm not sure if the previous owner put these on or they were done at the factory. The previous owner already had the plastic oem charge pipe replaced with an aluminum charge pipe at a very reputable independent bmw shop so I don't have to worry about that. So far I've replaced the battery with a new AGM battery, fuse #66 to fix no power coming from the front socket power outlet, and I've changed the engine oil and filter with LIQUI MOLY SPECIAL TEC LL 5W-30 & a Mann Filter. My plans for the car include the following; *iDrive, Map, and vehicle software update* *Trans fluid drain and refill (new ZF Lifeguard 8 fluid, trans oil pan, and filter)* *Rear differential fluid drain and refill (Liqui Moly 75W90 Fully Synthetic Gear Oil)* *Continental ExtremeContact DWS 06 tires* *Hoen H8 yellow endurance fog lights* *BMW floating wheel center caps* I was debating between getting a Audi A4, MercedesC class, Lexus IS 350, 335i or an Infiniti Q50. Everyone, what are your tips and advice for a first time BMW / Euro car owner??? Again I come from the world of Infiniti, Acura, and Lexus. What's the best way to get my vehicle software updated??? What are the best bmw parts websites for discount genuine oem parts???? Will I destroy transmission by doing the drain & refill @ 70k miles using the ZF trans service kit. Pic attached below. Last edited by Str8ghtSix; 11-01-2019 at 09:11 PM.. |
11-01-2019, 11:35 PM | #2 |
161
Rep 446
so far, i see all the preventative maintenance had been done including charge pipe. car should last long..
for software update, I'm sure there is a bmw website that you can put your VIN down and download it. put it into usb and plug into the car.
Mod bug will bite you if you buy a BMW ================================= |
11-02-2019, 01:41 AM | #3 | |
4528
Rep 5,392
Drives: 2015 BMW 335i x-Drive Auto
Sounds like you are on the right track. Definitely do the trans service with the ZF kit from FCP Euro. They have best price on it. Have someone experienced do it. It's not difficult but it's a very specific temperature sensitive procedure that a novice could screw up. FCP Euro is fine for replacement parts or google part number and see who comes up. I use GetBMWParts website (a discount dealer in MD) to keep my rip-off local dealer honest on very specific dealer only type parts. Kies Motorsports videos on YouTube will teach you a lot. Your CP is done so top maintenance issue taken care of. For #2, keep an eye on gasket for oil filter casting at front of engine. Replace immediately at any sign of oil leak to prevent potential damage later. Change spark plugs every 60k. Stock Bosch w stock gap is fine. NGKs only if you ever do Stage2 tune and mods. I'd probably change coolant every 60k too. Change brake fluid every two years for safety. At next change have them install StopTech stainless steel brake lines, about $106. Much better brake pedal feel. When you need pads, Hawk 5.0 are better than stock pads in every way. Rotors, go with Zimmermann- German made better than BMW because they are also zinc coated against rust at a fraction of dealer price. You don't say where u r from for tire climate. If you are going to ditch runflats then don't go halfway with all seasons. They are decent in all categories but great in none. Go with Summer Michelin Pilot Sport 4S. Amazing dry and wet. For winter/under 40 degree Fahrenheit seasons go with Michelin X-Ice i3 for excellent handling cold compound in dry or wet and excellent in snow. Quieter than Blizzak. For heavy snow areas, Blizzak WS90 are best. Assuming a stock square setup with 18x8.0" wheels, stock 225/45-18 size is fine for winter tires because wider tend to float over snow instead of digging through it controllably. But for summer go with either 245/40-18 for best handling or 245/45-18 for best comfort plus fills up wheel wells a little more for a dropped look. Same thing when shocks need changing. Koni Special Actives are a good choice. Also Bilstein. A mild drop spring (~3/4") like Eibach can replace worn out stock springs for a better ride combined with the new shocks but without the added harshness/stiffness of most spring kits. That's my advice for maintenance oriented stuff as you requested. Plenty of other ideas if you decide to get into mods. See Kies videos for lots of ideas too! Hope this helps! |
imperfectluck426.50 |
11-02-2019, 04:22 AM | #4 |
2966
Rep 6,003
Just curios if any on here have experienced a transmission failure. I hear about charge pipe failures and hpfp failures on stock cars but never transmission which bmw says is lifetime fill weather people did that or left it alone since it is sealed. Though apparently zf says it should be serviced.
11-02-2019, 10:30 AM | #5 | |
215
Rep 558
11-02-2019, 06:31 PM | #6 | |
1999
Rep 2,499
imperfectluck426.50 johnung4528.00 |
11-02-2019, 11:25 PM | #7 | |
4528
Rep 5,392
11-03-2019, 02:42 AM | #8 | ||
2966
Rep 6,003
11-03-2019, 12:17 PM | #9 |
238
Rep 878
My car has had the transmission replaced under warranty. No idea why it was replaced and was done under the previous ownership.
