2010 2011 BMW 5 Series Forum F10 High Flow Catted Downpipe w Stock Exhaust |
10-29-2019, 08:32 PM | #1 |
Rep 72
Hey Guys,
Looking to see if anyone has a sound clip/video w a high flow catted downpipe still matched up with a stock exhaust. Ive been searching on YouTube, but coming up short. Thanks. |
10-31-2019, 08:16 AM | #2 | |
12978
Rep 18,721
Aftermarket downpipe with cat is 1 out of 50 transaction. So, to find someone that is in it and make a video about it, even more rare. But, from my experience of dealing with many of them. It sounds a little louder than stock. I would say about 30%-40% louder. Especially on cold start. But not as loud as catless.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
10-31-2019, 09:41 AM | #3 |
9160
Rep 14,521
I ran across a YouTube video of a stock exhaust with aftermarket DP awhile back but can't find it. it's pretty common most people run DP's with aftermarket exhaust vs with stock exhaust. doesn't make sense to run a DP with a factory exhaust since most people are looking for a louder sound. that video was a bit louder but nothing to justify upgrading the dp if you're looking for more grunt
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~ Follow me on Instagram: lsturbointeg |
10-31-2019, 10:44 AM | #4 |
17
Rep 38
I actually run this setup on my 535.
Stock exhaust with 200 CPSI catted RM downpipe (ebay) Sound increase is minimal. While cruising, I would say same as stock. When driving aggressively turbo whistle is more prevalent. I used to have a stock dp with M-performance exhaust, which caused excessive drone and why I went back to stock mufflers. I have a 6MT, so i think drone is more pronounced because of different (from 8at) cruise RPMs and using larger throttle inputs in higher gears (w/o downshifting). But now with hi-flow catted dp and stock exhaust no issues at all. I am using MHD stage1 with catted dp and upgraded intercooler. I was planning to run stage 2or 2+, but these mods improved the power delivery and spool enough, that I am sticking to stage1 for now. |
lsturbointeg9160.00 |
10-31-2019, 10:55 AM | #5 | |
Rep 72
The 535 Im looking for the same thing. Afraid a catless downpipe with the stock exhaust may be too loud. |
10-31-2019, 12:03 PM | #6 | |
9160
Rep 14,521
11-01-2019, 07:24 PM | #7 |
64
Rep 431
I am running a catless dp with stock exhaust. I wish it was slightly louder at times but i don't miss the droning associated with aftermarket dps.
11-02-2019, 09:37 AM | #8 |
9160
Rep 14,521
Are you running a defouler to prevent the CEL since you don't have cats?
11-02-2019, 08:45 PM | #9 |
64
Rep 431
Negative! I am running a custom tune that takes care of any CELs that may otherwise show up. Bought the ER catless pipe here on the forums and love the power it makes.
11-03-2019, 07:49 AM | #10 |
280
Rep 1,305
I just installed Gutted OEM Down pipe on a meisterschaft full exhaust with Valve(s) delete.
Sounds great no drone at all. Defouler isnt working once i hit highway speed i got CEL. first week the smell was bad second week the smell was a little better third week way better but i still don't like it we are going to re-torque some bolts and put longer tips on if not better in 30 day i am going back to cat. The power is GREAT with out tune. |
11-03-2019, 10:00 PM | #11 |
9160
Rep 14,521
Do you guys know if the car runs in limp mode or runs differently when the CEL light is on? I'm wondering if the car adjust because of the no cats?
11-05-2019, 01:20 PM | #12 |
411
Rep 1,128
Stock mufflers with any catless downpipe, car will not drone, slight increase (probably 5-10%) in sound.
M Performance with catless will drone. M performance with 200 cells downpipe will have less drone, but if you have PS2 turbo, you can reduce drone by adjusting wastegate to 6.5 inHg |
11-05-2019, 02:54 PM | #13 |
280
Rep 1,305
02-07-2022, 11:16 AM | #14 |
Rep 8
Hello , im running a stock dp with a valvetronic armytrix exhaust from the cat and further .But im not very happy with the sound. Now looking what catted dp solutions i can find to make the sound louder. Reading though now it makes a slight only sound difference when catted im sceptical again ..
02-07-2022, 02:35 PM | #15 | |
9160
Rep 14,521
02-08-2022, 12:47 PM | #16 |
Rep 8
Yes idd catless sounds great , problem is its illegal here .So id have to mount it on and off at every yearly check we get in the Netherlands. Thus either this or stuck with a catted dp .I could match the dp to the exhaust from the same brand i suppose but i dont think armytrix makes also catted dp's? In the past i drove a 353 cabrio with dual m performance mufflers only and everything else stock , now i got a full armytrix with quad endpipes and still dont get the same sound loudness (or burbles) even though its both cars a n55 engine...Even removed all the insulation from the inside surface of the hood to "hear more" but all i got is the turbo hissing sound a bit louder only...Also plenty droning on low rpms(which i dont find bad btw)...Idk maybe it has to do with the "executive line" kinda feeling a limousine is supposed to have in contrast with the sportive loudness of a roadster chassis? Questions questions ..
04-30-2022, 06:27 AM | #17 |
18
Rep 30
Drives: BMW F11 535i MSport
I run a catless dp with a M Performane exhaust on my F11, no drone or cel, louder on startup and when giving her beans otherwise sounds stock.
535i F11 Msport, Masata IC, Masata Charge Pipe, Masata Turbo to IC pipe, BMS Air Intake, K+N Oil Filter, Catless DP, Stage 2.5, Brembo Brakes + EBC yellow pads.
