NAV Retrofit - Are CIC and CCC dashboards equivalent?
10-28-2019, 04:35 PM | #1 |
69
Rep 460
I'm trying to figure out a cost-effective method to retrofit CIC navigation to my 2008 E90 which has no navigation at this time.
Can I use the dash from a CCC-equipped model and just update the screen and other modules to bring it up to a CIC model? Or are the dashboards actually different in the 2nd hump area? Thanks |
10-28-2019, 06:03 PM | #2 |
50
Rep 243
Yes, your correct. If you choose to buy a dash from a prelci e90 and go through all the electronic logistics, then you could technically just drop in the new cic screen and navigation.
Current: 08 335xi Sedan - ST Suspension Coilovers - M3 Front Strut Brace - COBB Stage 1 - ECS Tuning Chargepipe + BOV - aFe Stage 2 Intake - Precision Raceworks Ignition Coils
10-28-2019, 06:08 PM | #3 |
98
Rep 121
Yes, the dash is 100% the same, down to the trim pieces. In a CIC retrofit for a CCC-equipped car, you literally replace just the screen, the headunit and two wires. The trim for the controller is different, though. Also, the glovebox has a small piece of trim for the USB port in a CIC-equipped car; CCC-equipped cars have a flashlight in that piece of trim instead.
10-30-2019, 12:50 PM | #5 |
1458
Rep 1,912
10-30-2019, 08:15 PM | #6 |
398
Rep 1,579
If you are pulling the dash yourself, try to get the power/data wiring for the controller and screen. The CCC screen power plug will need to be changed but the CCC pins fit into the CIC plug. At a minimum, get enough wiring to reach the back of the radio.
