10-25-2019, 10:33 PM | #1 |
YOURLOCALSTUNTER
Rep 3
Maxed out on bolt ons. Whats next?
Before i get started, here is a list of my current mods on my 2012 328I "sport" with M/T.
Dinan Dual Core Intercooler Dinan Big Turbo MST inlet pipe ER charge pipe Mishimoto CAI Wagner down pipe Muffler delete GFB DV JB4 (Map2 normally / map 7 when running E30+) 45mm Vent Boost Gauge Stock motor Stock Clutch (CM FX350 soon) Stock Flywheel (CM Lightweight Billet Aluminum Flywheel soon) I was wondering what i should do next? Once i get the new clutch and flywheel, i'm basically done with the "bolt ons" available for this car. I plan on either bagging or coilover-ing the car at some point but am focused on pure performance as of now. I haven't made it to a dyno yet but plan on making a trip this upcoming summer or whenever i can. Ive thought about upgrading the pistons and rods but so far the motor has not shown any signs of not liking the power it has now. I also want to invest in good oil cooler as im sure the stock one isnt performing as good as it should. |
10-26-2019, 06:47 AM | #2 | |
Uhh... Khakis?
54
Rep 155
10-26-2019, 08:12 AM | #4 |
2963
Rep 5,997
Bootmod3
Jake From State Farm54.00 |
10-26-2019, 07:31 PM | #7 |
143
Rep 242
Drives: 2013 328i 6mt
Switch to bootmod3 and get a custom map made to really get all you can get out of the new turbo
F30 328i 6mt
Injen, ER, BM3, Solowerks, IND, BMS, BBS E46 M3 smg2 Bimmerworld, H |
alohasurftoad3079.50 |
10-26-2019, 08:13 PM | #8 |
Gettin It Figured Out
1820
Rep 2,669
Impossible to give you honest feedback without knowing what your ultimate goal(s) / vision are...
10-26-2019, 10:43 PM | #9 |
1599
Rep 3,748
I think he's ultimate goal is just to spend money. Without a dyno... this is just about spending money.
I guess I could help you spend that money....do custom body modification i.e wide body custom, custom paint, cf hood, cf trunk. |
10-26-2019, 11:12 PM | #10 | |
1820
Rep 2,669
better yet, if he's throwing money around...ditch the N20 and go B58 or S58 .
B58togo808.50 |
10-26-2019, 11:59 PM | #11 |
809
Rep 1,369
This. If you're that hungry for speed, you need to start with six slugs.
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
10-27-2019, 12:46 AM | #12 | ||
1599
Rep 3,748
Nah man tuning i4 is fun.. you just need goals. |
10-27-2019, 01:05 AM | #13 | |
1820
Rep 2,669
You're absolutely correct.....my apologies for offending you, and/or whatever pronoun you identify with....🍻 . .
TX55248.50 |
10-27-2019, 02:10 AM | #14 |
49
Rep 76
Nah hes right its annoying hearing the whole "YoU sHoUlD'Ve BoUgHt ThE 335" spiel most people aren't willing to just drop their current car like what.
F30 328i MSport Mods: Bootmod3 Stage 2, MPE, VRSF Catless Down Pipe, G-Plus FMIC
Previous Cars: e36 323i vert, e90 328i sedan |
10-27-2019, 04:27 AM | #15 |
42
Rep 94
In this case, it makes sense to say he should've just bought an n55 and dropped the same amount of money into as this 328i. Everyone has preferences, but a tune n55 is faster than all this he did into his 328i.
10-27-2019, 10:16 AM | #16 | |
1599
Rep 3,748
Stock class vs unlimited class... have you seen one. Gt300 vs gt500 .... have you seen this race. Let me know please. Maybe the OP want to enter a circuit.....lol |
10-27-2019, 01:25 PM | #17 |
68
Rep 241
First, you need some suspension and chassis work to effectively put the additional power down. Second you need some additional suspension and chassis work if you want the car to be fast in anything but a straight line.
First- springs/dampers or coils Second - bushing work ( ts and lca, rear sub) Optional - more camber up front via 30min hubs, f80 LCAs, or camber plates,sway bars, LSD Also what do you run for tires? Boot some good rubber on. |
floridaorange10163.00 |
10-27-2019, 06:31 PM | #18 | |
2070
Rep 2,639
Its the answer we always give because it's the right answer. Stop throwing thousands of dollars into the car that you could probably use for trade in.
Bootmod3, CTS Catless DP, B58TU HPFP, XHP, BM3 Flexfuel Kit
ronanz1819.50 |
10-27-2019, 07:32 PM | #19 | |
1599
Rep 3,748
Come on man might as well say you start with LS1 and drop a turbo on it. You sound like a big block head like most of my friends with camaros, mustang, chargers or corvette. Why stop with a 6 cyclinder. |
10-27-2019, 08:23 PM | #20 | |
2070
Rep 2,639
N20/n26 is not a tuner motor unless you're willing you spend over 15-20k on it. What's the record 1/4 mile pass on them? We never see it here because most of the guys go and buy a b58, N55 or S55. If you can make this motor go fast, by all means go ahead. Stop at 6 cylinder because everything is more affordable than the 8s, and not to mention most places have more taxes on big blocks. |
10-27-2019, 09:29 PM | #21 | |
1599
Rep 3,748
But the OP seem to not have a goal |
10-28-2019, 06:18 PM | #22 |
#im_2_Fr3sh
30
Rep 247
Interior upgrades? Custom seats with half roll cage for style or for track use... nothing wrong with a 4 banger... and people say get the 6... rather get the 8... like to each they own... Yal hating and criticizing too much than appreciating the build... a lot of Yal lost that passion... now it's get a 6 and if it ain't pushing a minimum 500 then they ain't doing what they suppose to.. all I can is that the 4 banger is more reliable than the 6.. speed wise it's decent when tuned.. and it's great to have over 5/600+ horses but we ain't got the roads to do that over here without cops posted up everywhere.
2014 428i xDrive F32 | Injen Cai | Er Intercooler | Er Chargepipe | Er Tic Pipe | Er Catless Downpipe | Bm3 - Cary Jordan tuned 93 oct | Gfb Dv | Ngk L/I Spark Plugs | Cf High Kick Trunk Spoiler v1 | Black Grilles | 35% Suntek Tints | Michelin pss4 | Awe Quad Exhaust w/ Resonated Midpipe | Interior Mods | Mst Turbo Inlet | Pure Stage 2 Turbo | Arp rod bolts | Fuel-it Stage 2 Lpfp | Braum Elite x seats | Mishimoto Oil-catch can |
