10-23-2019, 05:50 PM | #1 |
Rep 14
F30 N47 328d injectors and compression
Hey folks,
My car is a F30 328d xdrive with an N47 engine with 91k in it. Car runs perfectly. Last week I replaced all four injectors. In the last 10k 3 error codes were present - most of the time - for cylinder 1,2 and 4. Namely: 24C000 , 24BB00 and 24BD00 All three was for: “ ZERO QUANTITY ADAPTATION INJECTOR CYLINDER 1,2 and 4: PERMISSIBLE FILTERED ACTUATION CORRECTION TOO HIGH “ Replaced and programmed all four injectors. Also, at the same time I did a Compression test for all four cylinders, Here are the measurements: Cylinders 1,2 and 3 were between 220-230 and cylinder 4 was 255 psI All those codes are gone. Now I have a new code: 2A6D00: JOGGER CYLINDER 4: CORRECTION AMOUNT OUT OF RANGE After that, put another injector to Cylinder 4, same error, and the car now lacks power and torque. Two question: 1: Could anyone give me any info on the new error code? As I couldn’t find any info about it. 2: Also, the compression measurements are in the optimal range for this engine? Don’t think it is related, but a DPF ERROR just popped up since: 27EF00: PARTICULATE FILTER SYSTEM: REGENERATION FREQUENCY TOO HIGH All new injectors are OEM, and injector replacement, programming and compression test was done with OEM BMW Equipment. Any advice would be greatly appreciated. |
