10-21-2019, 04:25 PM | #1 |
15
Rep 63
IDrive intermittently failing
Intersted if anyone had had similar problem - having set up a sat nav route and driving along the iDrive suddenly fails to a blank screen.
A short while later the BMW IDrive connect logo appears and the system restarts with a "Starting Satellite Navigation" followed by the option to stop or continue guidance. Opting for continue guidance it continues to give instructions as expected - but sometimes after a while the system fails again and the above is repeated. Can be a real problem as it failed as I was trying to navigate out of the NEC at Birmingham at the time of one failure during the evening rush hour. If radio or media player is in use at the time this fails as well. Screen just goes blank as if the power to the unit had been disconnected. Also notice that on occasions the "Starting Sat Nav" takes a longer than normal time for the system to kick in |
10-25-2019, 09:52 AM | #2 |
15
Rep 63
As no replies I can only assume no other owners have had the same problem - however car has been into dealers to have the issue checked out.
Service advisor didn't seem surprised by the failure and suggested it could just be a case of reprogramming the iDrive which is exactly what's been carried out. Will see how it goes now - no more failures I hope? |
10-25-2019, 10:24 AM | #3 |
Rep 27
This happened to me 3 or 4 times, but when the mobile phone was connected to the USB port under the armrest. The whole system has been restarted. Nothing happens when it is not connected.
10-29-2019, 06:32 AM | #4 |
14
Rep 138
My 2016 idrive has not rebooted mid drive like that but I have experienced multiple hard freezes during utilization or boot of the navigation system. The entire idrive system has been replaced once due to these hardware faults already. The second time they reinstalled the entire OS, since then it's happened again a few times but I've found if I press and hold the power button for the radio for about 15 seconds it reboots the idrive system which most of the time resolves the issue.
10-29-2019, 06:58 AM | #5 |
15
Rep 34
Mine restarted constantly until i figured out it was due to the usb connection to my mobile. Stopped connecting my fone and never been a problem since
11-14-2021, 04:42 AM | #7 |
13
Rep 51
Hi as I've previously posted this believe it or not is a common issue it seems as your BM age's. Software in any computer need update's so why should your car system be any different. I've always been of the opinion that cars today are so reliant on their electrical systems and generally work well from new but as the systems age 5 - 10 years down the line then glitch's happen. Very annoying and generally costly they are.
