F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Strange Noise from Engine
ARMA SPEED
      10-21-2019, 07:40 AM   #1
kingmonkey8
81
Drives: BMW 428i
I have recently noticed a noise coming from the engine. It's like a low level growl after the rev's drop. I don't notice it under normal driving, just at low revs or moving from a stop. Can anyone help identify the noise.
Hoping it's not related to the dreaded timing chain issue.
F32 428i N20 manufacture date: 12/14
https://vimeo.com/user104211839/review/367751265/a092ef7f8b
      10-21-2019, 08:21 AM   #2
EDWYER
Yoda of mods
EDWYER's Avatar
1674
Drives: X5 RWD
2015 X5 RWD  [0.00]
2016 BMW M2  [10.00]
Video isn't working for me.
Current: 2020 Explorer ST (Agate Black Metallic), F15 SGM RWD
F87 AW (retired) F30 SBM 316rwhp/440rwtq (retired)
Follow me on Twitter: https://twitter.com/EdwyerCLT
YT: https://www.youtube.com/@DWYERGARAGE/videos
      10-21-2019, 08:33 AM   #3
sspade
sspade's Avatar
2466
Drives: F30
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
Oil pump growl. A lot of us have it... should go away once car is fully warmed up.
I have it on cold starts. 2014 328i with N26. Built 05/14, Munich.
      10-21-2019, 10:33 AM   #4
kingmonkey8
81
Drives: BMW 428i
OK, thanks for confirming. It has just started recently and I never had the noise on my previous F32 with 45k miles, just doesn't sound normal.
After the major problems with my previous car. I was worried it might be something else major. If it were to be something serious again. I think it would be time to give up on BMW. Just not fun if you're having to constantly deal with issues.
      10-22-2019, 04:19 AM   #5
kingmonkey8
81
Drives: BMW 428i
Checked the oil level and it was showing about a quarter between the min/max level. Will give it top up, see if that makes any difference.
      10-22-2019, 09:31 AM   #6
AndDown
Just Copacetic!
177
Drives: 2019 F22 230i MSport
My 428i had a soft growl starting off, noticeable in the 1st and 2nd gears. Technician diagnosed it to the A/C compressor although the car was still blowing cold air. Previously, had a one time drivetrain warning that was related to the compressor high pressure sensor having an issue.
'01 X5 3.0 AlpWhite
'16 428i GC AlpWhite
'19 230i MSptPkg AlpWhite
      10-22-2019, 10:43 AM   #7
kingmonkey8
81
Drives: BMW 428i
OK, will bear that in mind. I hardly ever turn the a/c on.
I topped up the engine oil and I can barely hear it now. But the engine was warm at the time. Will keep a eye on it, to see if it's intermediate.
      10-23-2019, 01:23 AM   #8
IAmATeaf
IAmATeaf's Avatar
238
Drives: 2015 F30 335i
2015 BMW 335i  [0.00]
If you don’t periodically turn on the ac it will fail which will be very expensive should you decide to get it fixed.
      10-23-2019, 04:13 AM   #9
kingmonkey8
81
Drives: BMW 428i
So how often should I periodically run the a/c?
      10-23-2019, 04:20 AM   #10
Londoner
Londoner's Avatar
168
Drives: 340i msport+ MPPSK
I get the science behind this but in 15 years of owning A/C equipped cars I only ever turn on from June - Sept and have never had an issue.
      11-07-2019, 09:37 AM   #11
kingmonkey8
81
Drives: BMW 428i
Topped up the engine oil and the car generally seems quieter. Although sometimes there is a similar noise as before but not as loud.
I always have the HVAC fan on low but A/C off and have noticed that when it is making the noise normally at low speed when starting off or coming to a stop. If I turn the fan off the noise shuts off abruptly. So sounds like it could be to do with the HVAC or HVAC motor. Other times there is a bit of a low tickety noise that comes and goes.
      11-07-2019, 07:38 PM   #12
CrumbyButter
CrumbyButter's Avatar
25
Drives: BMW 320i xDrive
If you keep the climate control set to Auto it will run the A/C as needed. Also even if its manually turned off the A/C will come on if the interior gets too humid.
f30post
