10-20-2019, 01:47 PM | #1 |
26
Rep 106
What's in your toolkit?
My f30 didn't come with a tool kit. I'd like to put together a tool bag/box for the trunk. Some tools are obvious, but I'd like to know what you guys/gals have in yours. Essential and nice to have. Thanks buds!
10-20-2019, 04:44 PM | #2 |
¯\_(ツ)_/¯
945
Rep 1,762
- Philips/flathead screw driver
- Set of torx drivers - magnetic tool - 8/10/13/16/18mm sockets - 1/4" flex head ratchet with built in extension - 3/6" ratchet extensions - zip ties - 17mm wheel socket (the one with the plastic trim) - inspection mirror - breaker bar (forgot the size but probably 2 feet) - small channellocks - set of random small pliers - digital tire pressure gauge - electrical tape - vlair 85p air compressor
Tensioner/belt DIY | Side skirt extension DIY
Apex SM-10/DWS06+ | 400m/X-ice Xi3 | Injen Exhaust | Stoptech SS Lines | 335 Front Brakes Hawk HPS 5.0 | RBF600 | ER Charge Pipes | Wagner Evo Comp 2 FMIC Last edited by Solidjake; 10-20-2019 at 04:52 PM.. |
10-20-2019, 09:28 PM | #3 |
119
Rep 191
The number to my Chase Reserve card (free roadside assistance) and a key to my wheel locks. Also keep a tire mobility kit as my F32 doesn't come with a spare.
10-20-2019, 09:45 PM | #4 |
1365
Rep 1,031
Drives: Like a bat out of hell.
What tool kit? I didn't think BMW put in a tool kit since the E series. I don't even have an air compressor in mine.
10-20-2019, 11:26 PM | #6 |
1365
Rep 1,031
In that case.
1. Air compressor 2. Tire pressure gauge 3. First aid kit 4. Pliers/adjustable wrench 5. Screw driver; phillips, flathead and torx bits 6. Clean rags 7. Flash light 8. Jumper cable 9. Duct tape |
10-21-2019, 05:46 AM | #7 |
¯\_(ツ)_/¯
945
Rep 1,762
Forgot to mention a good quality scissor jack and tire plug kit
Apex SM-10/DWS06+ | 400m/X-ice Xi3 | Injen Exhaust | Stoptech SS Lines | 335 Front Brakes Hawk HPS 5.0 | RBF600 | ER Charge Pipes | Wagner Evo Comp 2 FMIC |
10-21-2019, 11:38 AM | #9 |
451
Rep 469
My cell phone - nothing else.
DD: F48 X1 xDrive25i '20 - https://f48.bimmerpost.com/forums/sh....php?t=1703083
For fun: F22 M240i '19 - https://www.2addicts.com/forums/show....php?t=1644646 Previous BMW: Fully loaded F30, 335i https://f30.bimmerpost.com/forums/sh....php?t=1681247 |
10-21-2019, 06:11 PM | #10 |
4517
Rep 8,942
Dead blow hammer isn't a bad idea if you plan to change tire yourself.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
10-21-2019, 09:31 PM | #12 |
26
Rep 106
A couple guys read it and posted some good suggestions. I don't want to change the engine by the side of the road. Just tools that might help me limp home in a bind. Thanks to the two of you who took the time to provide a list.
10-21-2019, 11:46 PM | #13 |
451
Rep 469
I believe my suggestion was god as well.
In my first car back in ’96 I had a similar list even though the car was brand new. Within less than 1000 miles I stranded and the tool kit couldn’t help me because I had a double puncture. I however kept the tool kit in the car for something like 6 years or more without ever using it so I removed it. Since I stranded 23 years ago our household has driven about 450k-500k miles in total and no car has ever left me stranded in a way that could have been solved with a tool kit. Oldest DD was a 22 year old BMW Z3 so they haven’t just been new cars. If I wasn’t using run flats I would have taken a tire repair kit and compressor as well but that’s it. Even when I have been to the track I don’t bring a tool kit. So what I am trying to say is that the/a tool kit never ever saved me and that is why I only bring my cell phone.
10-22-2019, 06:18 AM | #14 |
4528
Rep 5,392
Drives: 2015 BMW 335i x-Drive Auto
FYI- F30 has a tiny tool kit in the right alcove of the trunk in a small lift up panel above the battery. It's nothing to speak of (a tow hook, screw driver) but I did learn recently that an empty spot with a plastic clip is meant to hold a wheel lock key! BMW tech told me that he always looks for it there first.
10-22-2019, 08:18 AM | #15 | |
4528
Rep 5,392
Don't really need the spare for local daily driving stuff. In the trunk under the floor compartment I carry this list of stuff mostly bought at Harbor Freight and Walmart. Scissor jack with rectangular top that fits into BMW jacking point Small piece of plywood to fit under jack if it's muddy or soft groun Breaker bar, 21", 1/2" drive Plastic baggie containing: ____17 inch 6-point socket (1/2") ____Wheel lock key ____(4) original wheel bolts ____Long screw-in stud to assist wheel mounting Slime "8-minute" kit with air compressor Cheap mechanics gloves Cheap moving blanket Cheap plastic tarp Small waterless hand cleaner Plastic baggie containing my BMW specialty tools just so they're with car so I can't misplace them: ____Oil filter housing wrench ____Spark plug socket ____BootMod3 OBD2/Ethernet cable |
10-22-2019, 08:43 AM | #16 | |
48
Rep 104
10-22-2019, 08:52 AM | #17 | ||
4528
Rep 5,392
Hope this helps! |
jbb238847.50 |
10-22-2019, 08:55 AM | #18 |
336
Rep 963
Air compressor, tire pressure gauge, a 10mm socket with ratchet, and a couple of trim tools
the 10mm socket is basically just for the battery if i ever need to kill the car. lesson learned from the time my horn get stuck on during my morning commute |
10-23-2019, 01:40 AM | #19 | |
E36fiend
285
Rep 637
Drives: 2014 435i xDrive
Solidjake945.00 |
10-23-2019, 09:22 AM | #20 | |
48
Rep 104
09-04-2020, 11:21 AM | #21 |
Rep 12
Bringing up an older thread since a search didn't show anything like I am looking for.
I just bought a 17 340i Xdrive and am looking for what tools to get that I don't have already. New to BMWs but have been working on cars for years. I have all the normal handtools like full metric sets in 1/4, 3/8 and 1/2 drive plus wrenches, pliers, screwdrivers etc.. I also have some power tools, trim removal tools, pick set and OBDII reader. My question is what special tools are often needed for working on BMWs such as E torx, oil filter housing wrench, special spark plug socket and such? If there is a post or thread covering this please post a link or link to a site that has a list of tools commonly needed. TIA |
