BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > DIY Guides and Instructions > Oem exhaust modifications
      10-20-2019, 08:02 AM   #1
Zeezu541
21
Drives: F20 M140i || M3 F80|| F90 M5
Hi guys I have an M140i and want to modify the oem exhaust by opening the backbox and either:
1: replacing the perforated pipe with a straight pipe
2. Welding the holes in the perforated pipe
Could anyone advise which is a better method
      12-29-2019, 02:57 PM   #2
Matthew_W
Drives: M5 F10
From what I've seen on opening them I think it would be easier to replace the pipe as welding the holes around the back might be a pain. Saying that welding a new pipe in will have similar challenge although there may be enough space to get the torch around the back. Perhaps sleeving over the pipe would be simpler, ie slit a new pipe then put the seem on the opened side only.
I bought the MPE from Cotswold in the end and was very happy with it.
My m135i is going now and I couldn't get the MPE off. I've a feeling it's the same exhaust, my standard one is kicking around my garage if it's any interest for practise? I'm a fair way, but at least same country I think.
      01-08-2020, 06:02 PM   #3
DrGadget
DrGadget's Avatar
Australia
43
Drives: M140i F20 LCI-2
2018 BMW M140i  [0.00]
Exhaust flap solution
I took the easy and less noisy way out:
  1. Opened the exhaust valve by using such as Bimmercode/Carly for BMW or putting the car in Sports mode with engine running.
  2. Pulled the plug from the actuator, and installed a BMW dummy actuator plug (BMW OEM Part No, 18302411427) to keep the crap out.
  3. Strapped dummy actuator & wire to under-body with long cable tie.
  4. Installed wiring plug connector terminal 4 pin (BMW OEM Part No. 12527549033) to actuator valve mechanism after sealing with silicon to stop water & crap ingress.
  5. Exhaust flap stays open all the time.
Current: Alpine White M140i F20 LCI-2, 250kW/335hp, 2018.
Sold: Melbourne Red 340i F30 LCI Luxury Line MMPK - 265kW/355hp, 2016.
Sold: Alpine White 123d e82, 2010, 150kW/204hp.
Search this Thread:
Advanced Search
1addicts
