10-18-2019, 11:00 AM | #1 |
49
Rep 142
New X5 45e on it's way
Just signed an order for my next car, delivery expected in March 2020.
Ordered 18/10/2019 Update 04/12/2019: Status still 111, Production w15, expected delivery w21 Update 18/12/2019: Nothing changed Update 06/01/2020: Nothing changed Update 03/02/2020: Nothing changed Update 02/03/2020: Nothing changed Update 23/03/2020: Status 112, Production ?, expected delivery w24 Update 05/05/2020: Status 105 No production week available. (it went to this status on 01/04/2020) update 20/05/2020: Nothing changed update 03/06/2020: Production w38, delivery w45 update 01/09/2020: Status code 150, delivery w44 update 15/09/2020: Status code 153 update 23/09/2020: Status code 165, delivery w43 update 14/10/2020: Car arrived at the dealer update 28/10/2020: Car parked in my garage for the first time :-) C3Z BMW Individual Tansanitblau II ZAEI BMW Individual extended leather Merino bicolor Elfenbeinwei~- Nachtblau/SchwarzW) Standard equipment (not exhaustive) 1CB Internal code 1DE Particle Filter 2PA Anti-theft bolts 2VB Tire pressure display 2VR Adaptive pneumatic suspension (2 axles) 302 Alarm system 423 Velvet carpets 4T8 Mirror package 4U9 Acoustic pedestrian protection 4UR mood lighting 5A1 LED fog lamps 5AQ Active Guard Plus 6AE BMW Teleservices 6AF Intelligent Emergency Call - eCall 6AK ConnectedDrive Services 6C4 ConnectedPackage Professional 6U3 BMW Live Cockpit Professional 7CG BMW warranty up to 3 years, without kilometer restriction 886 Manual Dutch 8AP Internal code Z21 With monogram ZPE BMW Pure Emotions ZSL Fast charging cable 337 M sports package 1XN Alu wheels styling 741 21 "M bicolor 2NH M Sport brakes 2TB Sport automatic gearbox Steptronic with gearshift paddles 3MC Roof rails in Shadow Line high-gloss 4M5 BMW Individual dashboard covered with 710 M sports steering wheel 715 M Aerodynamics package 760 Shadow Line hochglänzend 775 Headlining Anthrazit ZB1 Business Pack Plus 322 Comfort access 456 Comfort seats in the front with electrical control 4HB Heat Comfort Package in front 6NW Comfort telephony with wireless charging 6WD Preparation WiFi hotspot ZT1 Customer Benefit Pack ZB3 Innovation Pack 3DS BMW Display Key 552 Adaptive LED headlights 5AC High Beam Assist 5AU Driving Assistant Pack Professional 5DN Parking Assistant Pack Plus 610 Head-Up Display 6U8 BMW Gesture Control ZT3 Customer Benefit Pack ZB4 Travel Pack 402 Panoramic sliding roof 413 Separation network 417 Mechanical sun blind for windows from the rear doors 418 Luggage compartment package 4FL Travel & Comfort System ZT4 Customer Benefit Pack 258 Runflat tires 3AC Trailer coupling with electrically retractable bulb 3DZ Without monogram on the flanks 3KA Acoustic glazing 420 Rear window glass 44A Cup holders in the front, heated and cooled 453 Active seat ventilation at the front 4A2 Interior elements with crystal finish "CraftedClarity" 4HA Heated front and rear seats 4KK Decorative frames in Aluminum Tetragon 4NB Electronically controlled air conditioning, 4 zone regulation 688 Harman / Kardon Surround Sound System 6DR BMW Drive Recorder 7M9 Shadow Line hochglänzend with additional elements 868 Voice version Dutch ZKS Safety Kit ZOR Non-reduced power [img]https://i.ibb.co/86fw7zj/cosy-Sec-6.jpg[/img] [img]https://i.ibb.co/cXgGjZD/cosy-Sec-5.jpg[/img] [img]https://i.ibb.co/cxjcz8P/cosy-Sec-4.jpg[/img] Last edited by awosy; 10-28-2020 at 12:04 PM.. |
10-29-2019, 07:05 AM | #3 |
49
Rep 142
Thanks, I went for a test drive with a X5 45e this morning.
My impressions: - The floor in the trunk is higher compared with the non-hybrid, but for me personally this doesn't matter. It's a big car with plenty of space which is more then enough for my daily needs. - I had the impression the sound in sport mode was a bit less then the 40i model. Not sure if this is just me, or if there is really a difference. - When starting the trip, the car said I could go 52 km electrically. I have done 20km electrically in my test drive of 60 km and it was saying I could still do 48 km, so I'm guessing with my driving habits I can easily get 70km of range out of it. The petrol usage was 8.2l/100km. (I did small roads, high way parts to get a good idea) |
10-29-2019, 08:13 AM | #4 | |
12
Rep 26
Thank you for your feedback |
10-29-2019, 08:41 AM | #5 |
49
Rep 142
Good question. For me personally, it felt too slow in this mode. I doubt I would do a lot of high way overtakes in this mode for example. But I may be biased because I'm used to having a lot of torque in my current car.
10-29-2019, 09:24 AM | #6 | |
12
Rep 26
Did you try the air suspension during your trip? My dealer told me that you can only use 2 or 3 position when you drive and one more (the lowest) when you are park. If it's true is a little bit sad if ou can't use it with the lowest position beacause it gives a very sport look in my opinion |
10-29-2019, 09:36 AM | #7 |
49
Rep 142
I didn't really play with it, but I noticed it changed itself when changing driving modes. I did try the button at the trunk to lower the suspension to see the difference in case you need to take out heavy things from the trunk.
Sport mode definitely does what you expect, even hybride mode felt very quick already |
11-20-2019, 06:16 AM | #10 |
12
Rep 26
11-20-2019, 07:14 AM | #12 | |
21
Rep 58
Fingers crossed you get back to the original delivery date. |
11-20-2019, 08:20 AM | #13 |
51
Rep 14
BMW BELUX and the dealer have already re-ordered my new X5 45e as I ordered in April 2019. My first burned down last week :-(
BMW will try to push the production date to ASAP, technically that could be delivery at the dealer within 10weeks ... Not sure if they will push that hard ?! |
11-20-2019, 08:29 AM | #14 |
10794
Rep 27,588
sweet build, nice
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST! Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101 vipfinance@bmwofcamarillo.com for warranties! |
11-20-2019, 12:55 PM | #15 | |
49
Rep 142
I'm not really worried about the delivery. (although waiting on new toys is not fun) My current car is not a lease and is still running perfectly, so there is no hurry. It does have 210k km on it, I'm guessing I will reach 235-250k around delivery of this one. It will be for export so it shouldn't matter too much on the remaining value. Thanks Damn Americans, since when do they care about hybrids, didn't see many last summer, only a lot of cars that you can only dream of in Belgium. (unless you are very rich and don't care about taxes) |
2REP20.50 |
11-25-2019, 08:38 AM | #16 | |
44
Rep 63
Somewhere in september the dealer told me my production week was set on W47. This has changed to W15, somewhere around oktober 18th. Dealer has no clue why it was delayed, but says that i shouldn't expect it before april/may 2020. That's 4 months extra! |
11-25-2019, 09:16 AM | #17 | |
Rep 56
that is a pitty, i ordered mine 2 months earlier and I am waiting for it to be delivered around mid december at my dealer... My sales rep informed me that BMW AG did some reshuffle with the production slots... he had to disappoint quite some customers informing them that they had to wait some extra months... Good luck! |
11-25-2019, 10:30 AM | #18 |
49
Rep 142
My order clearly says the 31/03/2020. When i asked my dealer about how bmw deals with these 2 extra months, he said bmw does nothing for their customers. In my case, it's not really an issue, i will just add more miles on my current car. But i can imagine some people really count on the delivery date, so if bmw fails to deliver, there should be some compensation or solution offered at least.
i actually don't have anything official on paper or on email informing me about the delay too. i only asked my dealer. So i still hope i will have it by the end of march. |
11-26-2019, 04:30 AM | #19 | |
29
Rep 58
We ordered end of June and ours was pushed forward with a few weeks. Was expected for W51 but the car just arrived in Zeebrugge and will be at the dealer in W49. Really strange these differences |
11-26-2019, 10:13 AM | #21 |
Rep 56
12-04-2019, 03:56 AM | #22 |
49
Rep 142
Got an update from the dealer:
So ordered it on 18/10/2019 Update today: Status still 111, Production w15, expected delivery w21 Still a long wait ahead... |
