BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > 6HP26 Mercon SP
      10-17-2019, 06:47 PM   #1
Dr Diesel
Drives: 2009 335d
6HP26 Mercon SP
for those of you who have searched far and wide for some definitive proof if mercon sp is safe in our cars with the ZF 6HP26, here’s my pan after 60K miles of running mercon sp. car now has 135k miles. I did a drain and fill with mercon sp last time and this time did the bridge seal and valve body seals as well as a full fluid exchange. Used 15 quarts of mercon sp to flush out all the old and fill with new. Car runs and shifts great!
      10-17-2019, 11:17 PM   #2
BB_cuda
BB_cuda's Avatar
765
Drives: 2011 335D Msport, 2013 X5D
Were you doing a simo drain and fill to try to dilute the fluid in the torque converter?
I’ve toyed with idea of disconnecting transcooler line coming from trans while doing a simo feed of fluid. I did this on another make and it worked quite well.
      10-18-2019, 09:32 AM   #3
Dr Diesel
Drives: 2009 335d
Yeah I did a total fluid exchange by drilling out my old pan at the pump feed tube and running a 3/4” outside diameter vinyl tube into the pump feed. Drilled a few holes through the pan to drain and filled that Home Depot bucket with 12 quarts of fluid and ran it through. So the pump was getting only fresh fluid while never seeing any mixed old / new fluid. Fluid started to change to new after about ~7 quarts based on height of fluid in the bucket. Setup worked great. It also worked for filling the new pan and topping off after warming, a lot easier then sliding under with a transfer pump.
      02-11-2020, 02:17 PM   #4
bait2212
Drives: BMW G31 540xD St+++
I also use Merson SP for 80,000 km. 6hp-28 E60 525d St.3 330Hp. The transmission feels perfect.
      02-13-2020, 11:23 AM   #5
BB_cuda
BB_cuda's Avatar
765
DR. D, I'd love to see a close up how you force fed the pump inlet. When you say pump inlet, I think of the outlet of the fluid filter where it plugs into bottom of valve body. My understanding could be all "wonky" though. thanks
      02-13-2020, 12:59 PM   #6
lnxguy
357
Drives: 2009 335D
Good stuff. Mercon SP is on my list for when it's time to do the tranny service.
'09 335D
