10-17-2019, 01:19 AM | #1 |
1486
Rep 1,268
Not another oil thread...
Hello, I live up in the frozen tundras of Minnesota during the winter. We do get pretty hot summers though. So, should I run different oils in these different seasons?
For instance run 5w30 in winter and 0w30 in summer? Also for the B58 engine should I bother with the 40 viscosity or just stick with the 30s? Please keep in mind that I drive the car hard; I don't track it but I do drive it like it is meant to be driven. |
10-17-2019, 12:56 PM | #2 |
Cheapskate
4450
Rep 4,993
If you do anything, you'd want to do the opposite. 0w30 in winter and 5w30 in summer. But no, it's not necessary. Run 0w30 year around and you'll be fine.
10-17-2019, 06:28 PM | #3 | |
4413
Rep 3,497
https://www.bobistheoilguy.com/.
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9˝ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro; GTechniq Crystal Serum Ultra Ceramic; Suntek PPF |
MightyMouseTech4337.50 B58_Ken240i3.00 |
12-12-2019, 01:59 AM | #4 | |
Rep 8
WolfGTI716.00 |
12-12-2019, 10:54 AM | #5 |
171
Rep 294
Drives: 2019 M240i Coupe RWD
12-12-2019, 11:44 AM | #6 | |
716
Rep 913
Drives: '17 F22,15 E84 M Sport,02 R53
Considering the -30 Temps - You can look at a 0 weight oil. I run a 5W40 all year around in NJ. I also don't go over 3000 rpm until the oil is over 180F.
12-12-2019, 01:35 PM | #7 | |
4413
Rep 3,497
FWIW, my Cincinnati dealer puts in 0W-20 year-round. OT, but TC Kline Racing told me that oil is good to use at the track. That advice came as a surprise; my frames of reference for track driving were the S50B32 and the S38B35, and each of those required much higher viscosity oils. For example, the S50 ran 15W-50 Red Line Race oil.
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9˝ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro; GTechniq Crystal Serum Ultra Ceramic; Suntek PPF Last edited by dradernh; 12-12-2019 at 03:39 PM.. |
WolfGTI716.00 |
12-12-2019, 05:34 PM | #8 | ||
130
Rep 274
12-15-2019, 10:43 AM | #10 |
445
Rep 1,264
10-30-2020, 05:52 PM | #11 |
Rep 50
What is the true spec?
Sorry to revive this old thread, but I am a bit confused and prefer to stay within spec while under warranty. I switched to 0w30 for my 1500 mile change. The manual specifies 0w20 or 0w30. When I went to take the car to the dealer for it's first included oil change they would not use 0w30 because they said spec is 0w20. Which is it?
Thanks all |
10-30-2020, 09:00 PM | #12 | |
Car Geek
3626
Rep 3,594
Various 0w30 and 5w30 oils meet the LL-01FE specs - BMW Twin Power Turbo LL-01FE 0w30, Motul 5w30 LL-01FE, LIqui Moly Special Tec B FE 5W-30, etc. https://www.bmw.ca/en/topics/offers-...0-1000-ml.html Various 0w20 oils meet the LL-14FE+ or LL-17FE+ spec - BMW Twin Power Turbo LL-17FE+ 0w20, Motul SpecificLL-14 FE+ 0W20, Liqui Moly Top Tec 6600 0W20, etc. https://www.bmw.ca/en/topics/offers-...0-1000-ml.html Look for these BMW specs on the oil label if not buying the BMW branded ones, but you won’t generally find them at Walmart or other big box stores. From the manual for my 2017 M240i: Last edited by aerobod; 10-30-2020 at 09:13 PM.. |
11-05-2020, 05:30 AM | #14 |
625
Rep 706
The thinner oils were introduced as a mpg improvement for the engines... Personally I don't like the 0 weight oils (too thin) and really though, it it's -30* outside are you going anywhere? Starting your car other than in an emergency? The thin oil makes the engine more noisey as well, I can hear the lifters more, the slightly thicker 5W oils improve that, especially the 5-40... Anyways ...
Again, with -30* temps, I wouldn't be doing anything but sitting on the couch sipping some hot coco, lolz! And if you are in a temperate zone that has those temps common, a vehicle with an engine block heater would be on the list because any oil is going to be troublesome at those extremes. Just my $.02 Just sayin |
11-06-2020, 02:04 AM | #15 | |
Car Geek
3626
Rep 3,594
0wXX weight oils are normal around here, with no apparent engine life issues, going by the older European manufacturer cars on the road which are typically the manufacturers that specify 0wXX oils as the standard grade. |
