BMW M5 F90 (2018+) General Forums F90 M5 vs...    F90 M5 vs F90 M5
      10-14-2019, 04:34 AM   #1
Bmw.mozambique
Drives: M5 F90 Competion
F90 M5 vs F90 M5
Hi everyone,
Firstly I hope this thread is in the right section.
Secondly I'm curious to know if there is any performance variance from a stock M5 F90 to another stock M5 F90? What causes it? Does newer MY models get faster?
Regards
      10-15-2019, 12:17 AM   #2
RustySeatbelt
RustySeatbelt's Avatar
523
Drives: 19 ZR1
2017 BMW M3  [0.00]
The driver and their skill level.
Aside from that, yes every car will be different and some are faster than others, although the difference will likely be negligible. There can be a lot of different factors, but mostly it's just due to variance in production. BMW does not intentionally make the newer model year any faster than the previous as long as they are the same model and package. A standard M5 will not be as fast as a M5 Comp, but same to same the difference will likely only be noticed when you factor in the drivers ability in the car.
      10-16-2019, 01:11 AM   #3
Phatcat
751
Drives: BMW M5, X5M
There will be performance variances. It is impossible for BMW or any manufacturers to make every M5 having the exact same horsepower and drivetrain loss.
      10-16-2019, 08:20 PM   #4
Stealth7
147
Drives: No BMWs Right Now!
Manufacturing tolerances are very tight now so there really should be no "hero" cars.
      10-17-2019, 12:38 PM   #5
Phatcat
751
Drives: BMW M5, X5M
That's what we strive for but cannot achieve. I'm in the automotive industry, and is a supplier to BMW. Parts in testing even made in the same batch will have variances in performance, and some by quite a bit.
Two autobild test on the M6 coupe. One test was in 2014 on the 575HP M6 CP it ran 0-300km in the 30 second range while in 2016 the 600HP M6 CP ran 35 seconds plus. Sure it wasn't tested on the same day but 5 seconds differences? And the 600HP was actually the slower one?
I do not believe differences are negligible, there bound to be some cars that are faster or slower.
DCT OFF61.50
      11-02-2019, 06:46 PM   #6
Hockeytyme
Hockeytyme's Avatar
575
Drives: 2020 M5C
I'm a big believer in what we always called "Monday cars" If you guys aren't familiar with the term, it means the car was built on a Monday when the guys were fresh and doing a better job..lol
I have had a few Monday cars and street bikes and a couple not so. I also believe that a lot has to do with how guys break in the toys. Not so much in cars but when I was riding street bikes they had very strict break in rules that I'm only recently seeing in cars.
The problem is that most people will just sit at 2-4k rps and almost wear grooves and smooth spots in those areas. So once the car/bike is broken in it's a bit limited or struggles to be a smooth at the high RPM's as things tighten up.
(Set the rings)
I'm all for breaking in my toys the way I plan to drive them. With some common sense of course. I don't race them around per say but I make sure to use all of the power band and RPM's but I shift and don't hold high RPM's either. In a perfect world I want my RPM's going up and down as much as possible during break in with cool down periods in between.
Turns out, I have in most cases ended up with the "Monday" bike or car over the years. Could be luck, could be how I break them in. Who knows. Just my two pennies
Race cars go out on fresh engines constantly, I have also had a few high end sand rails and other custom motors built and they have never told to me take it easy on break in. Maybe I'm wrong which is why I'm still somewhat careful. But, why is it that street bikes have always had break in rules and now faster cars? Why not the 330i? Conspiracy theorist would suggest that it's because they don't want us to kill ourselves in the first week and it gives us time to slowly get used to the car. Which is actually smart!
DME: 1848 DA 0-60 2.42 -- 1/8 Mile 6.38 -- 1/4 Mile 9.89 -- 60-130 5.91
Evolve: 1418 DA 0-60 2.48 -- 1/8 Mile 6.47 -- 1/4 Mile 10.05 -- 60-130 6.48
JB4: 1096 DA 0-60 2.54 -- 1/8 Mile 6.50 -- 1/4 Mile 10.05 -- 60-130 6.18
IG: @hockeytyme All runs on street with no prep on 21 inch wheels and PS4S tires
Appreciate 2
shoei7779.00
      12-04-2019, 07:40 AM   #7
Rusty34
Drives: 2016 550i M-Sport, 2015 X1
You may be right about that. Breaking in is more for the driver, not the car? I'm in the racing business and we can put a fresh engine on the dyno with no warm up time except for the oil and it will produce its best numbers right then and there. Modern precision manufacturing and finishing processes I guess.
      12-04-2019, 11:24 PM   #8
kyrix1st
kyrix1st's Avatar
2362
Drives: G87 M2; E92M3 MT&DCT; M3 euro
2004 BMW Z4  [0.00]
(Set the rings)
Interesting. What "break-in" rules do you follow?
Pass me if you can.
      12-04-2019, 11:32 PM   #9
Hockeytyme
Hockeytyme's Avatar
575
Drives: 2020 M5C
I broke my car in kinda hard. I was very easy for about 150 miles not revving above 5k.
After that I drove it fairly hard from time to time. Almost just like normal. I even did a couple 1/4 mile runs for baseline numbers.
My goal was to keep the RPMs moving up and down. Obviously there is times where it's at one RPM on the freeway for some time but I tried to get on it now and then. Just don't hold a high rpm. Let it wind out and shift
      12-23-2019, 09:32 AM   #10
Miko M
///M
Miko M's Avatar
6654
Drives: 2020 M2C. 2020 X3M
(Set the rings)
Some truth to that. I work in manufacturing and can see the difference.
Hope I don't get the car from Friday
Everyone is doing short cut on Friday and can't wait to get out
Life is too short...enjoy your life
///M
      12-23-2019, 04:53 PM   #11
marcvtec
407
Drives: M5
It also depends on how many Heineken's were had the night before
      12-25-2019, 01:41 PM   #12
KCTiger
523
Drives: 2016 X5M
I worked for a Tier 1 parts supplier and we did a statistical analysis on defect rate. Consistent with the above comments, defect rate on Friday was magically lower.
m5post
