10-13-2019, 01:00 PM | #1 |
46
Rep 194
CA smog test xdrive
Bought my 15 335i xdrive from Texas and when I brought it back to CA, had to be smogged. I thought I needed to find a smog test place set up for awd cars. Turned out not to be the case. The smog guy didn't put the car on any "dyno" or even stick that metal thing in the exhaust. He just turned on the car and checked if there were any check engine lights on. Has anyone else experienced this?
If this is really what they do, a catted downpipe is looking much more enticing. |
10-13-2019, 03:37 PM | #2 |
DisplacementReplacement
409
Rep 1,104
Most smog states and I would assume CA to do this check for OBD readiness along with the MIL. OBD readiness is the tricky part, not really the MIL>
2020 X3M /// MHD Tune
Prior Bimmers 2017 240XI Hybrid / FBO / MHD E40 2015 235XI FBO / MHD E30 2009 335XI FBO / COBB / E30 |
pkiledj46.00 |
10-13-2019, 03:41 PM | #3 | |
4364
Rep 7,607
For your BMW, they will just plug into the OBD2 port and check readiness monitors. This will be things like O2 sensors, catalyst working properly, etc. Having said that, checking for readiness is NOT the same as just not having a CEL. Having a CEL is usually an automatic fail, but just because you have no CEL, does not mean all of your emission monitors are in "READY" state. Getting a catted DP and/or hiding the CEL with a tune will not put you in ready state. There are only 1 or two catted DPs that "guarantee" no CEL, and i have not seen many confirmations if any that these also show READY. |
10-13-2019, 03:54 PM | #4 | ||
46
Rep 194
10-13-2019, 08:06 PM | #5 | |
Typical Car Guy
55
Rep 25
I passed the OBDII, but left on my ER charge pipe on my old N54 and it did not pass the visual at the first shop. Hid the ER logos that they put all over their silicone and went to a second shop and it passed. Most shops aren't looking to fail you in CA, but they have to have their own backs if it is blatant. They have no idea if you are from CARB and trying to catch them slipping
'15 435i ///M Sport
CTS Intake • VRSF CP/Race FMIC/DP/TIC • MST Inlet • xHP S3 • 3.5 TMAP • Dorch S1 HPFP • Wedge Tuned |
pkiledj46.00 |
10-14-2019, 01:38 AM | #6 | ||
46
Rep 194
10-14-2019, 11:17 AM | #7 | |
4364
Rep 7,607
So yes, you could technically fail for a charge pipe. |
pkiledj46.00 |
10-14-2019, 11:23 AM | #8 |
175
Rep 211
I have a Scangauge II. When I used it on my tuned Golf R it showed no CELs but did show a Not Ready condition. On my Stage 2 335i with a catted Fabspeed it shows no CELs and a Ready condition. I'll be due for a smog test next time, 5 years here, so I guess we'll see if that Ready reading holds true.
Mineral Gray - Active Autowerke Stage 2 - MPerformance Suspension - VRSF CP - CTS Turbo IC - Catted Fabspeed - Akrapovic - HRE FF15
pkiledj46.00 |
10-14-2019, 12:20 PM | #9 | |
46
Rep 194
Did the tune get rid of the CEL or was there never a CEL after installing the fabspeed catted downpipe. |
10-14-2019, 12:52 PM | #10 |
175
Rep 211
AA Tune. Never mentioned needing CEL clearing to the tuner. They may do that to all Stage 2 tunes, but I really don't know. I did return to the stock tune for the annual service appointment and didn't get a CEL in the 50 or so miles I drove.
