10-12-2019, 05:58 PM | #1 |
5251
Rep 5,874
G20 Winter wheel and tire thread - post your setup!
Ok the winter season is fast approaching so let's use this thread to document how to go about winter mode on the G20. Hopefully this helps people figure out what fits. Post your setup!
I just installed my kit and I think it is FANTASTIC. Highly recommended for a performance OEM look. I bought via Tire Rack for a little under $2k pre-tax including TPMS. Installed without any issues, perfectly balanced, and tires seem to handle quite well even in today's dry 60F weather here. I live up a bunch of hills and drive in typical cold wet conditions with occasional snow and will also do some trips into the mountains. My car is an xDrive. MSW (OZ) Type 73 wheels, 5x112 Centerbore 72.6(?) Hub center rings included for BMW 66.6, fits snug 19 x 8 ET30 square setup Wheel bolts included look like a slightly larger cone seat than OEM bolts so I used them (although they're silver) BMW center caps fit perfectly Pirelli Sottozero 3 performance winter tires Size 235/40/19 (1.2% taller than OEM square setup) This setup compared to OEM by the numbers pushes toward outer fender by 2 mm in the front and sits at the fender the same in the rear although looks like a couple mm pushed out. Bolt torque 103 ft-lb Tire pressure 38 PSI all around The pics... OEM summer 792M with staggered PS4S: Winter mode OEM strut clearance Winter set strut clearance Close ups Fender aspect |
10-14-2019, 08:14 AM | #2 |
47
Rep 82
Looks great! I was very curious about the fit with the slightly different offset (32 vs 27/40) on those MSW wheels and the wider tires. Your pix confirm it. Nicely done. Especially appreciate the clearance pix and confirmation on wheel caps - I couldn't find any info to confirm how/if those would fit. Awesome.
I hope to add my own pix soon... |
10-15-2019, 11:43 PM | #4 | |
47
Rep 178
10-16-2019, 12:31 AM | #5 |
5251
Rep 5,874
10-17-2019, 06:01 PM | #6 |
935
Rep 4,326
Drives: M340
WoW, great job picking those wheels. At 1st look, I couldn't even tell the difference.
Very nice set up Transfer!
2020 G20 M340 xDrive - Portimao Blue - ZDA|ZPP|ZPX|1CR|1PE|6NW|6WD
2016 F10 535i xDrive - AW - Retired 2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired 2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired |
10-18-2019, 02:42 PM | #7 |
Rep 13
I got enkei 19' 8.5j TFR and all season Michelin Pilot Sport A/S 3+ from tire rack, still waiting for deliver. Will replace my 20' 795m P zero. I will see how this winter set works.
10-19-2019, 07:03 AM | #8 |
222
Rep 821
10-19-2019, 10:32 AM | #9 |
5251
Rep 5,874
Awesome I debated spending $$$ with BBs vs cheap and I'm happy with my cheapo setup but want to see those BBS!
10-20-2019, 09:38 AM | #10 |
71
Rep 130
Here is my set, very happy with the outcome. https://imgshare.io/image/jBXiO
https://imgshare.io/image/jBIp9 https://imgshare.io/image/jBikF https://imgshare.io/image/jBdAn |
10-20-2019, 10:25 AM | #11 | |
5878
Rep 10,253
Your setup looks great incidentally. |
10-22-2019, 12:51 PM | #13 |
222
Rep 821
10-22-2019, 05:48 PM | #14 |
47
Rep 82
Bmw 18" 796m
I'm pleased to confirm that the OEM 18" 796M set will indeed fit a M340i with the HP Tire & Cooling (ZTK) package.
Ordred them from my dealer. Took 4 business days to arrive. $2,4xx out the door, including dealer installation and storing the off-season tires. I've only driven on them for about 25 miles, but the ride quality is improved. Especially with temps in the 50's today, the P4S's were getting hard. Less crashy over bumps, and feels just as responsive in normal driving. Smooth and quiet at 75+. I'm very happy with the results. Before (yesterday), 19" 792M with Summer Michelin PS4S... Front... After, 18" 796M with Pirelli Sottozero... Front rotors don't look much different than with the 19's. Calipers are close but they're no tighter than with the 792M's. Last edited by Delta5; 10-22-2019 at 05:59 PM.. |
10-22-2019, 08:52 PM | #15 |
5275
Rep 3,947
I ended up getting a set of OEM replicas (with BMW center caps) in satin matte black. 19x8.5 225/40/19 square set up that will clear the ZTK brakes. I went with you my tried and true Pilot PA4's. I love those tires and didn't want to make a mistake.
Here are the wheels I got. |
10-24-2019, 09:25 AM | #17 | |
43
Rep 95
10-24-2019, 11:31 AM | #18 | |
47
Rep 82
Edit... Took a peek under the front, ZTK oil cooler is definitely there too Last edited by Delta5; 10-24-2019 at 06:29 PM.. |
10-26-2019, 10:59 AM | #19 |
21
Rep 23
I ended up getting a set of Continental WinterContact™ TS 860 S - 225/40 R19 and 255/35 R19 on my wheels 792M. According to Conti, premium tyres with optimum braking performance and safety
10-28-2019, 07:31 PM | #22 |
278
Rep 456
Smart question I like to know too for economic reasons. Let's not get overlying excited about the type of tires and rims but the sensors could/may be different and require coding or relearning. Or even partial incompatibility.
