BMW X5
      10-10-2019, 02:24 PM   #1
x5randy
x5randy's Avatar
Drives: 2019 X5 40i
Best radar detector for G05... in NJ
Looking for information about the best RD for the NJ area.
I had a old V1 in my 2012 X5 that worked great, but it never stopped beeping in the G05.
Yes, thanks, I've read about the gesture control issue. Which is why I'm upgrading my detector.
So, first has anyone tested a G05 with a Radenso pro M, ESCORT MAX 360c, or that new V1 by Valentine (that's been due out in 2 weeks - since April)
Second, how do they compare to the Uniden R7 that I see some users have installed? (regarding BSM, gesture control issues, and usefulness)
Third, what's best RD for NJ? I've read at https://www.vortexradar.com/ that the Radenso didn't have the necessary X-band coverage.
Thanks in advance.
      11-16-2019, 02:34 PM   #2
mvigod
mvigod's Avatar
182
Drives: 2021 X5M
Nobody replied to you from a month ago! Just saw this!
I used to have a V1. too many falses in NJ. waste of time with those. Just as you said never stops beeping.
My Escort Max 360 does not work in my 2020 X5 as the smartplug does not work with BMW lighter receptacles. Beyond stupid but Escorts reply to me was something like "yeah bmw uses a euro style socket". I would have preferred "yeah we have an adapter that will fit"
So forget Escort Max 360. I also would not trust the new Valentine.
Most likely I would look at the R7 next here in NJ. Would not worry about X-band. I don't think any cops in Jersey use X-band for quite a while now. Almost all are KA band and rarely laser for state troopers. maybe.
Only other option is a hard wired hidden install of an Escort 9500ci or something. That will run you about 4k to 5k I think properly installed with a set of front laser jammers. I have the best guy who can do it if any interest. I am thinking of it for mine. I just realized today the Escort Max 360 is a paperweight in the new X5.
      11-19-2019, 12:49 PM   #3
x5randy
x5randy's Avatar
Drives: 2019 X5 40i
Thanks for reply
RE your Escort
My very old Escort came with an adapter sleeve for european cars that worked. It looked like the image below.
RE NJ and Radar
I contact Radenso and Rin quickly responded. Here are my questions and their answers.
My Questions:
My old V1 doesn't work in my new BMW G05, always beeps - maybe gesture controls. I'm tired waiting for the new V1 and am looking at the Pro M and R7. So here are my questions:
1- Will the Pro M have the same issues with the gesture control? If so can I return it?
2- I've read at Vortex and Radar blogs that the Pro M may not be the best RD for NJ is that correct?
3- If I purchase a Pro M I'd like to remote it like my old V1. Will you be selling a Direct wire kit with a mute button & LEDs? I couldn't find one on your site.
4- Last question. I saw your video from SEMA, will you be developing a new RD with arrows & Rear detection that I should wait for?
Their answers:
Thank you for contacting Radenso! We have had a few users use their Radenso Pro M in their BMWs with gesture controls and do not have an issue with it. I will answer your questions in the order you asked them in:
1. It should not have any issues with gesture controls and yes, you can return it within 30 days if purchased from us. Amazon has the same return policy, but Crutchfield I believe has a 60-day return policy if you wanted to try it out a bit longer. Pricing is the same across all sites.
2. Customers in New Jersey seem to like the detector a lot out there. Especially if they travel to New York City a lot because they can enable MultaRadar detection.
3. We only have a direct wire kit for the Pro M. Since the power port is only for power, mute/LEDs is not possible without doing modifications to the board and case it self.
4. We are working on a new detector that will have full front and rear detection and arrows. We are expecting to release it around Spring time.
      11-19-2019, 01:39 PM   #4
mvigod
mvigod's Avatar
182
Drives: 2021 X5M
x5randy
Update on my Max 360. After I posted my reply above to you I did more research and found somebody who put some solder on the tip of the Max lighter plug to extend it a few millimeters. So I pulled out my solder gun and put a blob on the tip. Tried it out and it worked!
That was first problem solved. Second problem was gesture control. I had laser going off constantly. Some said to put tape over the gesture control emitter. Instead i moved the detector up and to the right of the rear view mirror. It worked and all the falses from the gesture control stopped.
Drove the car today and all worked.
I have to put some kind of safety in case the suction cup falls off windshield. That is a far drop down and will land right on the piano black trim. I don't think that would be good. I have the EZpass right next to the detector so might just do a simple hack with a bit of clear fishing line and loop it around the detector wire. This way if the suction cup falls off windshield the fishing line will keep the detector from crashing down on the dashboard or trim. Just a small loop so shouldn't be noticeable at all.
      04-16-2020, 04:24 AM   #5
RutWaller
Drives: No THanks
A radar detector is programmed and installed for the waves. Most of the tips of my assignment help australia are visited for the turns. The move is inducted for all radars. The plan is vital for the approval of the sites for the readers.
      02-26-2021, 02:48 PM   #6
chrisnack
152
Drives: 2019 X5 (G05) 50i
Old thread, but i run a Max 360c in the G05, ran it in my G01 M40I previously. Very happy with it, does a great job of filtering out false alarms and learning.
Stock smart code worked if you had it in the right spot, only used that for a week as then i hardwired it, which i always do. Also use a BlendMount to attach it to the mirror for a very nice clean install that is rock solid. Suction cup always falls off in the hot summer, take a look at BlendMount.
I turned off gesture control as i know it can cause issues and I don't ever use it.
      03-07-2021, 08:36 AM   #7
rsgg06
rsgg06's Avatar
34
Drives: BMW X6 Accord Ducati Diavel Di
https://www.amazon.com/UGREEN-Charge...77P629DS&psc=1
https://www.ugreen.com/products/dual...er-with-socket
I am using this for my Escort Passport 360 and works fine. No other interferences noted either. Adapter worked straight in trunk port but not in the front one!
2021 BMW X6 x40i; 2017 Ducati Diavel Diesel Limited Edition bike; 2018 Honda Accord Touring
2017 Audi A4; 2009 BMW 535i; 2006 BMW 530; 2007 Acura MDX; 2002 Cadillac Escalade
2001 Honda Odyssey; 2000 Lexus RX300; 1997 Jeep Grand Cherokee; 1994 Toyota Camry
      03-18-2021, 09:06 AM   #8
hdahman
hdahman's Avatar
237
Drives: BMW X5MC
not sure if I heard people complaining about gesture control on F95 and R7, is it true? thanks
      03-19-2021, 09:45 AM   #9
GREENPUS
133
Drives: 2019 BMW M5C
Originally Posted by mvigod View Post
x5randy
LOL. I reached over to the passenger door to open for my GF and my shoulder bumped the detector on the windshield. The suction cup released and the detector hit the floor and bounced once over the door sill and flew into the sewer drain on the road curb. Of course this was all in slow motion......
2019 M5 Competition
2021 X6 xDrive40i M Sport
2018 Toyota RAV4 AWD
2008 Corolla S Souped Up - The Black Widow
      03-19-2021, 10:02 AM   #10
chrisnack
152
Ouch... blendmount all the way!
GREENPUS133.00
      03-19-2021, 07:55 PM   #11
write4toma
Drives: BMW X5 G05
RADENSO is a beast, had a custom fit with Advance Laser Protection. Zero tickets on a Tesla M3Performance 400hp/400tq. It was on silent...just to see the flashing alerts that's it
      03-22-2021, 02:35 PM   #12
AwesomeM3
AwesomeM3's Avatar
1643
Drives: F95 X5MC
2015 BMW X5 M  [10.00]
2020 BMW X5M Compet ...  [0.00]
2008 M3  [10.00]
My Escort Max 360 does not work in my 2020 X5 as the smartplug does not work with BMW lighter receptacles. Beyond stupid but Escorts reply to me was something like "yeah bmw uses a euro style socket". I would have preferred "yeah we have an adapter that will fit".
BMW has a fix for that:
2020 F95 X5///M Competition CarBahn Autoworks Stage 1 | 2023 Lamborghini Huracan Tecnica
      06-24-2022, 12:04 PM   #13
PacShakur
105
Drives: BMW F80 M3
Instead of using the socket. Get a mirror tap kit (less than $20 from Amazon) and tap into the map light thus avoiding the cig lighter altogether.
      08-12-2022, 02:56 PM   #14
I2P
20
Drives: 2022 BMW X5 xDrive 40i
BMW Advanced Car Eye Pro 3.0 dashcam
Has anyone tried the BMW Advanced Car Eye Pro 3.0 dashcam?
      09-22-2022, 02:40 PM   #15
nog0odd3ed@gmail.com
43
Drives: 2023 X5 40i Msport
I wanted to look at the BMW CarEye 3.0 but when I asked dealer install price it got too expensive to install properly.
My new X5 has the iDrive recorder which works like that careye so I'm set now.
Sorry I don't have more positive answer for you
      04-15-2023, 04:32 AM   #16
Olga Huel
Drives: BMW
Thanks for this post <a href="https://www.google.com/">Google</a>
xbimmers
