Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > Transfer case died on me. Can I replace it with a used on?
      10-08-2019, 09:03 PM   #1
mrocha4
Drives: 2011 335i xDrive
Have a 2011 335i xdrive. The gears inside my transfer case are broken. And I need a new transfer case module. Actuator is fine. Can I use a a used transfer case on my car? BMW sales advisor says I cannot use a used transfer case because the module needs to be reprogrammed to the specific car and VIN? Local lesser known foreign car repair shop says I CAN use a used transfer case and that it won't need to be reprogrammed. Any help is appreciated! Thank you!
      10-08-2019, 09:14 PM   #2
relative4
611
Drives: '08 335xi E90 MT stage 1+
The stealer is full of sh!t. Keep your existing module & actuator motor, reset adaptations, have a nice day.
4 Doors1169.00
      10-10-2019, 06:02 PM   #3
PS2N54
79
Drives: 335i
a USED one will work, if the module is in fact VIN restricted, usually dealers wont re-program, but most indy shops with a good scan tool will be able to re-program the module for you.
      10-21-2019, 12:58 AM   #4
335xs2dinan
335xs2dinan's Avatar
141
Drives: 08 E92 335xi, 22 G80 M3
dealer installed a used one for me, no issues. 2008 335xi
Dinan Stage 3/Cobb FMIC/ER Sport Oil Cooler/CPE Catted DP/BMS DCI/Eisenman Race/Koni Yellow F + Dinan R/Dinan Springs/UUC F + R Sways/M3 subframe bushings/OEM 313 Wheels/M3 steering wheel
      10-21-2019, 09:27 PM   #5
mikes4
13
Drives: none
I had a local transmission shop replace mine with a used one for $2k total. BMW wanted something over $5k I think. No issues.
      11-12-2019, 05:00 PM   #6
Soravia
114
Drives: 2011 E91 Silver xDrive 6MT
You can buy a used one with low miles but you MUST replace the fluid with proper fluid for the ATC300 clutch pack in there. Most die because they believed BMW "life time fluid" lie.
$300 for clutch pack.
https://www.ebay.com%2Fulk%2Fitm%2F263364464140
You can also make the shop replace the inner clutch clutch pack, bearings, and the worm gear on the motor. All under $500 for parts
      03-07-2022, 11:46 AM   #7
JohnWizz
Drives: '06 325xi E91 wagon
2006 BMW 325xi  [0.00]
Hey, I know this is an older thread but I'm trying to find someplace to purchase a clutch pack for my '06 325xi transfer case. The eBay link you have is not working (and I'm assuming it wouldn't be correct for my car). Wondering if you could point me to the right place? I have tried searching eBay but I'm not coming up with anything. Probably just not searching for the right thing.
Thank you!
      03-07-2022, 05:41 PM   #8
Brian86
Brian86's Avatar
638
Drives: e36 M3, e91 325xi, N50 Xterra
www.car-part.com
Just get a whole transfer case.
My e91 325xi has a T-case out of a 5 series. I think it was about $200 and the salvage yard removed the donor unit from the old car.
Sometimes a bolt is just a bolt.
Appreciate 2
      04-04-2022, 10:33 PM   #9
Soravia
114
Thank you!
https://www.ebay.com/itm/263364464140
ATC300 Transfer Case Friction Clutch REPAIR KIT / BMW E60 E90 xDrive
https://www.ebay.com/str/all4transmi...75.m3561.l2563
Ships from Solvakia. Buy before Putin invades. Most Bimmer parts used and new come from there. I think OE parts factory is there.
      05-03-2022, 12:38 PM   #10
JohnWizz
Thanks for the links! I am thinking about just going with the junk yard replacement but I am torn because if I get the junk yard replacement, it could die as well. If I rebuild mine, at least I know what I have... This is me... OVERANALYZE...
      05-03-2022, 03:54 PM   #11
Brian86
Brian86's Avatar
638
Get a low milage junkyard unit.
Mine had 280k before I replaced it, and it worked perfectly except that the front output yoke was damaged by severely worn driveshaft Ujoints the previous owner left on.
Anything under 100k will do. It'll still be good and now that you're taking care of fluid yourself it'll go at least another 200k.
      05-15-2022, 07:35 AM   #12
Soravia
114
Originally Posted by Brian86 View Post
www.car-part.com
Upgrade that 325 into 330 intake and tune, also available from X3,X5, 5 series, and Z4.
