10-08-2019, 11:32 AM | #1 |
1106
Rep 1,499
FTP charge pipe...bungs not tapped correctly?
So I mostly installed my hodge-podge WMI kit this weekend. I bought it from a fellow forum member used. It has a Snow Performance pump and nozzles, AEM tank, LED and controller and an Aquamist flow solenoid. The kit itself works great. My issue is when it came to screwing the nozzle and NPT to 1/4" air line (for boost measurement) fitting into the CP. Neither would even get started threading. I ran out to Autozone and picked up an adapter kit which contained a 1/8 BSPT to 1/8 NPT thread adapter. The 1/8 BSPT adapter would screw into the CP no problem, which would be ok for the boost line, but it was a no go for the nozzle. The adapter interferes with the spray pattern.
Anyway, I was wondering if anyone else has had this issue with the FTP CP and what you did to fix it. I've gone ahead and ordered the 1/8" NPT snow performance tap from Summit Racing. My hesitation to tapping is having to remove the CP to tap the bung hole so that i can removed the tap shavings. I have two ideas to get around this. One, I can 3D print an adapter to my shop vac so I can attach a smaller diameter hose to it and stick it through the vacuum port used for the AT guys. Turn the vac on and get to tapping. Second idea is to zip tie a ballon to the end of my air compressor blow gun, stick the ballon through the vacuum port, inflate the ballon so it creates a seal and prevents the tap shavings from falling down to the bottom of the CP. I can disconnect the CP at the throttle body and stick the vacuum hose down and vacuum up the shavings. What do you guys think? FWIW I wrote to FTP and here is their response. hello sir Thank you for supporting FTP I am sorry to let your confuse Because the bung for the snow performance was changed twice It is now 1 / 8 PT ~ ~ so that you may have some difficulties So they are not fully tapped. I suggest you can use a tapping device (pictured a tap with tap handle) Modify its depth ~ that you can install
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI). SPI Films Blog/DIY Vids |
10-08-2019, 07:33 PM | #2 |
242
Rep 765
maybe re-thread it? if its already installed and you don't want to bother swapping it back out and ordering another brand or having them do it.
edit: just saw the last of your post, I would do what they recommended and go get a tap/die kit and just re-thread it.
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
10-09-2019, 08:10 AM | #3 | |
1106
Rep 1,499
Yeah that's what I'm going to and just make an adapter for my shop vac so I can suck shavings out from the AT vacuum hose port as I run the tap down.
10-09-2019, 10:51 AM | #4 | ||
242
Rep 765
10-09-2019, 12:10 PM | #5 |
A family of bimmers
2747
Rep 7,742
I dont think that would work with aluminum. Aluminum is pretty soft i cant imagine you would have many shavings when tapping it further
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills |
10-10-2019, 09:04 AM | #7 |
1106
Rep 1,499
Yeah if I can't get a good angle with the tap handle this is what I will do.
10-15-2019, 07:30 AM | #8 |
1106
Rep 1,499
This is what I ended up doing. It was due an oil change so already had the front of the car up on jacks. Removing the underbelly pan to get to the bottom clamp, then removing the top part of the CP was much easier then I anticipated. One out I was able to get a good view of how far I needed to tap to get the nozzle deep enough in the bung as to not have spray interference with the CP wall. The kit works great. After working through some iOS 13 issues with hotspot I was able to grab a couple of logs. Not bad for 75,000 miles on the engine. You can definitely tell the WMI is spraying as the added fuel impact the STFT. IATs are good but I think the impact will be more evident in the summer months and 90-degree weather.
http://www.bootmod3.net/log?id=5da4f40fae729b1b6cd87c09 http://www.bootmod3.net/log?id=5da5b55cae729b1b6cd87dca
