F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > forged pistons
Extreme Powerhouse
      10-04-2019, 06:46 PM   #1
Rhys22gnt
Drives: BMW 2012 320i
hi so after recently blowing my piston rings in cylinder 3 I've taken the plunge into forged pistons. my question is I've gone from the high compression 320i piston at 11:1 cp ratio, to Carrillo 9.5:1 compression, will the OTS bm3 maps still work without any issues?
other engine mods
mst inlet/intake
decat
charge pipes
dv+
arp rod bolts
thanks
forged pistons 9.5:1
arp rod bolts
mst inlet/intake
dv
bm3 stage 2
decat
ftp charge pipes
      10-05-2019, 03:33 PM   #2
rjd_F30
rjd_F30's Avatar
2000
Drives: 2013 335i 6MT
I would definitely talk to a tuner about that. Changing the compression ratio is a pretty substantial modification that I would assume should be tuned for.
Instagram: rjd_f30 | Current: EBII 2013 335i 6MT RWD & Sprint Blue 2008 Audi RS4 | Retired: 2013 328i, 2000 XTerra, 2022 Civic Si |
      10-09-2019, 07:29 PM   #3
Gen13 F36
Gen13 F36's Avatar
1599
Drives: 428i Gran Coupe
other engine mods
mst inlet/intake
decat
charge pipes
dv+
arp rod bolts
thanks
Just the piston? How about the rods and the deck/ sleeves?
      10-10-2019, 11:48 AM   #4
deviantspeed
poopycat
266
Drives: 2017 F31 330ixT
other engine mods
mst inlet/intake
decat
charge pipes
dv+
arp rod bolts
thanks
No.
Maybe.
Not recommended. Call up BM3 about a custom tune if you are going there. I wouldn't, even stock it would probably be a nightmare.
Is this them or just a "shop"? Seems like them:
BM3 Tuning NYC/NJ
639 East 31st Paterson,NJ Call/Text: 646.907.9439 or or (862) 823-2370 | 2890 Shell Road, Brooklyn NY
      10-10-2019, 11:49 AM   #5
deviantspeed
poopycat
266
Why does that even matter? Going 11:1 to 9.5:1 is not trivial. I can make some assumptions, but not going there.
      10-10-2019, 12:17 PM   #6
Gen13 F36
Gen13 F36's Avatar
1599
Well... I was thinking the OP is going for more power in the future. Why do piston if you can install more forged internal while the engine is open.
Just saying
      10-10-2019, 12:32 PM   #7
deviantspeed
poopycat
266
Just saying
Didn't see any of that assumption. Just saying.
will still need a custom tune.
      10-16-2019, 08:08 AM   #8
CandyRedRC46
CandyRedRC46's Avatar
242
Drives: 2013 328i
A compression of 9.5:1 will require considerably more timing and or boost/cfm to make the same hp as an 11:1 compression ratio (all other things equal). I wouldn't even think of doing this upgrade with out a much larger turbo that can support more more boost and cfm, rods as strong as the Pistons, sleeves as strong as the rods/ pistons and an auxiliary port fuel injection that could keep up.
      10-16-2019, 09:13 PM   #9
rjd_F30
rjd_F30's Avatar
2000
Yah, you don't just upgrade the pistons. Pistons are typically just a piece to a much larger upgrade puzzle.
      10-21-2019, 02:41 PM   #10
D041987
Big Turbo Boys N Girls
D041987's Avatar
327
Drives: 2012 328I 6speed
Def stick with 10:1 compression and get the rods while you are there. No sense in doing just pistons.... Rods are weak link with this engine above 360 Wheel Torque. If you just do the rods and pistons you can run about 450-500 HP safely with the open deck on supportive turbo and fueling upgrades.
2012 F30: G25-660 Bottom Mount Mani+ DP+ Intake, CSF FMIC, VRSF CP, Walbro 450 LPFP, PR Injection with AIC 4, S63TU Injectors, Tuned with BM3, ZF Race 4 Puck and Non SSA Pressure plate, Catless, 3.5" Quad Muffler, Custom Valved Bilstein B8 + H&R SS. Max 456 WHP - 452 WTRQ. Currently tuned down to 434 WHP and 362 WTRQ to save the rods.
f30post
