Rear on my Eibach Pro springs came out too low
10-04-2019, 09:11 AM | #1 |
140
Rep 362
Rear is a bit too low; Thought the Eibach Pro is supposed to be a subtle drop (.8 - 1inch)? Any idea why my stance came out pretty aggressive? Paired with Koni Sport Dampers. May have to swap out Rears to even a more subtle drop.
10-04-2019, 09:41 AM | #2 |
Slow.
3782
Rep 7,151
Drives: Single Turbo N54 on Meth!
Looks about exactly the same as when I had them. I too was surprised by how aggressive the drop was, not like them on many other platforms where you still have some wheel gap vs. tucking tire in the rear.
That being said I drove for 5 years like that with an Mtech front bumper and CF lip and never had any issues. The rear higher is going to look odd as your front will look like it is point down vs. being flat. You already have that big body line crease that points down. You will be fine.
10-04-2019, 10:08 AM | #3 | |
140
Rep 362
10-04-2019, 10:10 AM | #4 |
2183
Rep 2,806
What OP is likely experiencing is the downside of springs that are 1 (or maybe 2) sizes fit all. Is your car highly optioned (= weighs more)?
BMWP springs come in various rates and get selected for your car based on options. They do cost somewhat more than Eibachs and probably of no better quality.
E82 / BMWP Springs / Koni Yellows / M front control arms / Adjustable front endlinks / M rear guide rods / Whiteline Poly RSFB
10-04-2019, 11:47 AM | #5 | |
Slow.
3782
Rep 7,151
If the height does not interfere with your daily activities, driveway, speed bumps, etc. I say just keep it for a while and see if it grows on you.
10-04-2019, 11:48 AM | #6 | |
140
Rep 362
10-04-2019, 12:17 PM | #7 |
Guest
Rep n/a
Drives:
You could always swap the rear back to stock sport springs...they're the same spring rate, so it shouldn't make a difference...or shim them with appropriate height OEM rubber spring pads.
If you go Dinan, do Dinan all the way around...those spring rates are actually stiffer than stock, unlike the Eibachs. |
feuer4275.50 |
10-04-2019, 12:44 PM | #8 |
2183
Rep 2,806
AT vs MT is a pretty big weight difference. Also, options like power seats, navigation, sunroof add weight.
10-11-2019, 06:14 PM | #9 |
140
Rep 362
So just had my Dinan springs set up on both Front/Rear. Car does run much smoother, softer and much less bumpier. Rears look perfect but do wish the front were a bit lower. Hopefully it drops a lil as it settles.
10-12-2019, 12:57 AM | #10 |
Save the manuals!
6015
Rep 6,746
Damn that is slammed. It looks much more like Sportline than Pro Kit. Sure you got the right springs?
I've never seen any E9X be that low on Pro Kit.
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
Fritzer944.50 IllSic_Design2124.00 |
10-14-2019, 10:44 PM | #11 |
No one sleep in Tokyo
945
Rep 1,507
Drives: 2011 E90 328i//1995 E34 530i
Get the E36 bump stops or the lowering perch for the front to balance it out with the squatted rear.
2011 E90 328i, 1995 E34 530i, 1992 E32 740i, 1991 E34 525i
Seattlesquash894.50 |
10-14-2019, 11:58 PM | #12 |
140
Rep 362
Interesting..do you have a link for lowering perches?
10-15-2019, 09:59 AM | #14 |
165
Rep 1,402
Drives: 06' E46 M3 ZCP
Are you saying to get the e36 lowering perch?
19’ F90 M5C | Signature VS-104 | M-Performance | IND | H&R
06’ E46 M3 ZCP | Karbonius | Ohlins | Vorshlag | Turner | Kassel | IND | Status Gruppe | Macht Schnell 03' E39 M5 | 100% Stock |
10-15-2019, 10:21 AM | #15 |
140
Rep 362
Putting new Turbos in next week (Pure 600). Maybe that will add to the front drop as well.
10-15-2019, 10:59 AM | #16 |
945
Rep 1,507
Made by Supreme Power, don't have a link.
10-15-2019, 11:01 AM | #17 |
945
Rep 1,507
E36 front bump stop + Supreme Power Lowering Perch should be about 1" drop in the front.
10-15-2019, 11:23 AM | #18 | |
140
Rep 362
Also which is the correct part #? I see both labeled e36 Bump stops: 31332225377 https://www.ecstuning.com/b-genuine-...h/31332225377/ 31331124449 https://www.fcpeuro.com/products/bmw...op-31331124449
10-15-2019, 11:54 AM | #19 | |
165
Rep 1,402
E36 bump stops are shorter. They're commonly used used to add additional shock travel when lowering springs are used. very popular mod in the e9x M3 fourm
10-15-2019, 12:07 PM | #20 |
165
Rep 1,402
10-15-2019, 01:12 PM | #21 | |
140
Rep 362
10-15-2019, 06:20 PM | #22 |
165
Rep 1,402
Nice! I already had the bump stops from previous use M, but I also just ordered the perches. Waiting on the invoice now.
SpunkyXL139.50 |
