iDrive Controller Wiring
10-03-2019, 07:41 PM | #1 |
40
Rep 58
Has anyone here hooked up an iDrive controller to an aftermarket headunit? I have a PAC module that retains steering wheel controls, and also support iDrive. I have been thinking about using an iDrive controller to have more programmable buttons.
I am assuming non-iDrive cars do not have the wiring for the controller, how would one go about that? This is just an idea i had, and may not be worth the effort.. |
10-03-2019, 08:23 PM | #2 |
1917
Rep 13,114
I would say take this question to the idrive subforum.
Never seen it done here. https://www.newtis.info/tisv2/a/en/ you might be able to look up schematics in the above. There are updates to the idrive at Bimmer Retrofits. com NBT Evo versions for instance. |
10-21-2019, 10:27 PM | #3 |
490
Rep 1,309
idrive controller is just 4 wires. power, ground, can high, can low. You can pull them from anywhere, pretty much, and it'll "just work"
unless you get a 10-pin idrive controller. Don't get that one. Also, don't get an f-series idrive touch controller. that uses can2, which is a different bus speed and won't work. |
