09-30-2019, 03:43 AM | #1 |
97
Rep 373
m4 pads in mperformance BBK
hi All
does anyone have the part numbers for the m4 pads i want to use them in the MP BBK thanks, (apparently there are normal m4 pads and then sport m4 pads or something any one have any further information?) does anyone have any feedback on these pads in the MP BBK vs the stock pads
'14 F20 M135i EWG FBO:// INJEN INTAKE // PURE INLET// TURBOSMART BOV DUAL PORT // //CSF INTERCOOLER // ER CP // SNOW S2.5 METH KIT // B58TU HPFP // NGK 97506 // ER DP // TMSS MID PIPE //MPE // MPBBK // UR STRUT BRACE // BM3 CUSTOM JORDAN E85 TUNE // XHP STAGE 3 // |
09-30-2019, 10:12 AM | #2 |
3850
Rep 2,874
I have the factory BBK and it uses the same pads as the m235; didn't look to see if that is the same size as the m4. I'd call zeckhausen racing for brake info - they'll know if they interchange, and will be able to give you some advice on whether this is a good swap for your uses (good street pads can be lousy in performance applications, and vice versa). Lots of crossover pads that work well across both settings if you can live with noise and dust, more limited options if you can't.
10-02-2019, 04:33 AM | #3 | |
97
Rep 373
10-05-2019, 04:14 PM | #4 |
284
Rep 566
M Brake Pads / Front
Standard: 34112284969 Sport: 34112284765 M Brake Pads / Rear Standard 34212284989 I think the rear sport pads are the same as standard M pads. They fit the M-Perf BBK just fine. I've had the standard M pads on my M-Perf BBK and steel brake lines for almost 2 years and I run them in winter. I think they are fine and I think they have better initial bite, perhaps a bit better overall, but I also think that some of it is due to the steel brake lines and I also think maybe I should have stayed with the original pads. I swapped when I already had the steel lines. I don't track that car but I do occasionally drive aggressively for long runs... 250-300 km highway going 200-240 km/hr or so which, of course, includes some hard braking and stops... and over time I noticed some vibration when braking medium to hard... and I think it may be due to the more aggressive M pad than what's supposed to be coupled with the brake kit and, therefore, some uneven wear and deposit on the rotors. It's not horrible but I do notice some vibration. Occasional noise when cold but not bad at all. Lots of dust, just like the original pads. Last edited by x233; 10-05-2019 at 04:24 PM.. |
10-11-2019, 06:01 PM | #5 | |
97
Rep 373
10-13-2019, 12:07 AM | #6 | |
230
Rep 555
The pads are the same though as the calipers themselves are the same. So you can freely run M4 pads either OEM or aftermarket.
10-19-2019, 02:09 PM | #7 | |
Supreme Allied Commander
3857
Rep 54,419
Drives: F80 M3
PM, email or call us if you have any questions. |
