BMW
X1 / X2
BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Dead spot 2.0 Auto?
      09-28-2019, 01:34 PM   #1
Bluedave789
Drives: BMW X1
2018 X1  [0.00]
Dead spot 2.0 Auto?
Hi
On occasion I seem to have a dead spot on my new X1, i go to pull away and there is no go, then all of a sudden it is 4000 revs and wheel spinning away. This is not always I hasten to add its very sporadic, does any one else have this issue?
      09-28-2019, 02:03 PM   #2
Beagler
75
Drives: Sept 2019 Facelift X1 MSPORT
Had that with my Tiguan DSG and was annoying. Thankfully not with the X1.
Everthing goes to Entropy in this Age.
      09-29-2019, 08:42 PM   #3
satz
Australia
336
Drives: 2019 BMW X3 M40i
bluedave, I have a similar issue with my 2019 X2 (petrol, 2.0litre with 7 speed DSG).
It jumps to 4000rpm on the tacho very quickly, with lots of noise, but takes a second or so for any actual action...
Happens sometimes from standstill, but also occasionally when on the move and I need to accelerate fast with a stomp on the gas pedal.
Didn't bother checking with the dealer as of course it probably won't happen when they test drive it....
2019 X3 M40i, Sophisto grey, H/K, pano
Previous: 2019 BMW X2 Msport, Mineral Grey, Adaptive Suspension, H/K
Previous: 2009 335i LCI, Bluewater
      09-30-2019, 01:23 AM   #4
The Beast
The Beast's Avatar
268
Drives: VW Transporter Sportline
Sounds like it’s the DSG gearbox, as our 2016 20i with the Aisin 8 speed auto doesn’t do this. You should report it to the dealer as there may be a software update for the gearbox. We had an issue with a Mercedes DCT gearbox that was resolved via a software update some years ago...
      10-01-2019, 02:30 PM   #5
ttimbo
ttimbo's Avatar
282
Drives: F48 X1 25i AW; F20 M135i AW
7sp DSG or 8sp auto transmission?
If the latter, there's a 'reset' process to try, as follows:
1) hit start button once to turn on power (Don't start the engine)
2) then press the accelerator down to the floor for 5 sec
3) then hit start button once to turn off power
4) then remove foot from accelerator
5) then wait for 2 minutes
4) then start the engine like normal and see if that helps with the jerk and acceleration hesitation
The transmission ECU is, like most, a 'learning' unit; that is, it watches how you drive most of the time, and then develops a shift pattern to match. The thing is, that pattern will not suit a change such as a "spirited drive" when you usually engage in the afternoon commuter. The process above just resets the ECU, and lets you train it again. Worth doing every few months, in my experience.
BMW F22 M240i; F48 X1 25i, BMW F20 M135i
Peugeot T9 308 GTi 270
Renaultsport Megane 3 Trophy-R, Renault Clio Sport 182.
      10-04-2019, 08:10 AM   #6
MJE60
MJE60's Avatar
England
678
Drives: BMW G01 xDrive M Sport
Originally Posted by Bluedave789 View Post
Hi
I had a similar problem on my old freelander (which had an earlier generation 2.0d BMW engine). The problem was a faulty MAF sensor. It may we worth getting it checked. You do not say what model you have, i.e petrol or diesel, they have different gearboxes also, which might be relevant. Good luck, hope you get it sorted.
      10-10-2019, 12:23 PM   #7
Bluedave789
Drives: BMW X1
2018 X1  [0.00]
Hi sorry its a 2.0 petrol (my bad) I am calling the dealer to get it booked in thanks
      10-14-2019, 04:45 PM   #8
satz
Australia
336
Unfortunately the reset process didn't do anything on mine (7 speed DCT)...
Took the car to the dealer, but they said the 'lag' was normal for this car.
      10-15-2019, 09:34 PM   #9
ttimbo
ttimbo's Avatar
282
Not intended for that gearbox, unfortunately — only the 8sp Aisin auto
xbimmers
