Recommendations on clutch replacement?
09-26-2019, 05:34 PM | #1 |
Rep 9
Hello all! This is my first time posting.
Car: 2008 bmw 335i, 100% stock. 131,000 miles Problem: clutch is starting to slip. My background: I was a mechanic for several years before becoming an engineer. I do not have the time to perform a clutch swap (single parent of two). Any recommendations on a clutch replacement kit? Go with OEM materials or aftermarket? My mechanic is quoting $1400 including OEM clutch kit. I do like the performance of a lightened flywheel, so I’m open to that. Not sure what people’s experiences are with those on this car. Car is stock as I live in CA and can’t afford to risk smog. |
09-27-2019, 12:10 PM | #2 |
320
Rep 1,023
Use an OE or OEM instead of BMW-branded - it will save you a bunch of money! Other than that, I'd just recommend stock replacement of the clutch, pressure plate, and throwout bearing. Here's a LuK kit that should get the job done: https://www.fcpeuro.com/products/bmw...it-21207567623
I'd recommend against a lightweight flywheel for your car's usage - they tend to come with a lot of downsides that only make sense if you have a very dedicated car.
2001 e36/7 M Roadster 5spd
2008 e90 335i 6spd 2011 e90 335xi 6spd 2011 e70 x5 diesel 2010 Ducati Monster 696 |
09-27-2019, 12:29 PM | #3 | |
Rep 9
Have you to anyone else noticed a down-side to using a LUK or otherwise OE part VS the BMW part? I'm a little anxious since most of the cost will ultimately be in labor. |
09-27-2019, 12:36 PM | #4 |
Enthusiast
92
Rep 269
If you want a better clutch you can direct swap in a 335is one. It can handle more torque and is the same price. Unsure what your power goals are, but if you plan on keeping it stock then I wouldn't even bother with a lightweight flywheel.
$1400 seems steep. Which part of LA are you in? I can refer some good Indy shops that specialize in bmw's with better pricing.. |
09-27-2019, 12:41 PM | #5 |
douchebaggo
186
Rep 972
$1400 is not really out of line if it includes a new DMF, which is $600 on fpceuro. $500 for labor sounds reasonable on a clutch job.
09-27-2019, 12:45 PM | #6 |
Enthusiast
92
Rep 269
09-27-2019, 12:56 PM | #7 | |
Rep 9
What manufacture do you recommend for the stock replacement clutch? I don't think he included a replacement FW but I know he only used BMW parts |
09-27-2019, 01:02 PM | #8 |
douchebaggo
186
Rep 972
09-27-2019, 01:54 PM | #9 | |
Enthusiast
92
Rep 269
Offset Motorwerks in Glendora - Excellent Prices and quality work but a bit distant from Glendale Johanns Independent Mercedes in West Hollywood (they work on bmw's mainly though) - Mike is VERY honest and they do good work, very busy usually IKONIC Auto Garage in Los Feliz - Hear great things, haven't gone there but they're closest to you The M Shop in Cypress Park - A bit costlier than the ones above but they do great work |
09-27-2019, 02:49 PM | #10 | ||
Rep 9
Separate question: Who on these forums is the expert on what I can and can't do to my car in SMOG-crazy California? I'm interested in working on some modifications for throttle responsiveness and power as I'm sure my turbo replacement is coming due, but I really don't want to deal with failing a smog check. If the risk is high right off the bat, I will just keep everything stock. |
10-23-2019, 06:01 PM | #11 | ||
Rep 9
