How to avoid negative camber?
09-26-2019, 01:51 PM | #1 |
11
Rep 81
I will be installing a set of H&R sport springs on my 2011 e92 M sport and I want to avoid my rear wheels cambered in looking lopsided and wearing the tread on the outter tires.
Is there a recommended camber kit that works best with my model car/ H&R racing springs? Or other alternatives to reducing rear wheel camber? Thank you
Here to learn!
09-30-2019, 03:17 AM | #3 |
87
Rep 236
Drives: e92 335iA
I would guess that he meant what to do when the rear camber can not be fixed to oem specs any more using the excentric bolts... in that case get adjustable links/arms or replace possible bent item (if we are not talking about a really low setup)...
"If everything seems under control, you're not going fast enough.” Mario Andretti
