Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > Turbo drain pipe / oil pump
      09-25-2019, 12:36 PM   #1
DG330
70
Drives: 330
Hi,
Has anyone had issues with a turbo drain pipe being restricted or blocked? If so what was the symptoms of it? Was it noticeable?
Chasing a blue smoke issue, wondering if it could be a restricted drain pipe. The garage said I had a leak on the drain pipe which they resolved, but unsure if they worked out why it was leaking, was it a restriction in the pipe or just a simple o ring.
Oil pump - do these ever go wrong and over pressurize? Would too much pressure restrict oil flowing back to the sump from the turbo?
      09-25-2019, 01:37 PM   #2
335dlci
277
Drives: 335d
Well VCG are common
      09-25-2019, 02:41 PM   #3
Yozh
Yozh's Avatar
No_Country
870
Drives: 2011 335d M-Sport
If your turbo drain pipe is blocked your turbo will fail quite quick.
